Valve Cover fitment
Dec 1, 2004 | 01:37 AM
Valve Cover fitment
Anyone with a 1992 Vette and aftermarket valve covers?
Will the later composite valve covers fit?
Looking for more clearance for Roller Rockers.
Dec 1, 2004 | 03:41 AM
If you have center bolts you will have to cut the drip rails inside the cover.
Dec 1, 2004 | 11:01 AM
St. Jude Donor '05
I decided to go with the later model composite covers on my 92 and picked them up for $190 or so. Lo and behold I needed special bolts which were prob $30? Then lo and behold I needed special studs which screw into the head and the special bolts screw into them another $40 or so. Then you'll need the oil cap another $10.
Long story short I love the way the later composite covers look but is it really worth almost $300 for valve covers?
If I had it to do over I'd get some billet ones there is a company making these and they're beautiful but I can't think of the name.
Dec 1, 2004 | 01:09 PM
i would recomend saving your money and just cust back on the drip thingys in the cover. i was having the same problem so i grinded off where it was touching. 92lt1 w/ 1.6rr
Dec 1, 2004 | 05:11 PM
I still like the look of the OEM 92 valve cover (polished--of course)
Dec 1, 2004 | 05:20 PM
St. Jude Donor '05
Quote:
dang those are sweet
I just sold mine last week for $20
Dec 1, 2004 | 05:23 PM
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
I dont want to know the amount of time it took to do that.
Dec 1, 2004 | 05:26 PM
Quote:
Okay, I won't tell you that it took me a couple of days.
Dec 1, 2004 | 05:28 PM
St. Jude Donor '03
They do look very nice thats for sure.
Dec 1, 2004 | 05:33 PM
Thanks and for the original poster, I have roller rockers under them. I just had to cut the oil drip tangs off with a dremel tool and cutting wheel. (Crane self-aligning narrow body RRs Gold Series)
Dec 1, 2004 | 09:20 PM
Thanks for all the responses
Specifically I am looking at Scorpion 1.7rr's I think they are too big to fit under even modified stock covers.
I am just worried about aftermarket valve covers fitting under the alternator bracket.
Dec 1, 2004 | 10:41 PM
St. Jude Donor '05
check with Nathon Plemons I'm pretty sure he's running the Scorpion 1.7's
Dec 2, 2004 | 11:29 AM
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
I think that they will fit if you cut off the tabs. But good luck getting those rockers. I tried and gave up and just went with 1.6's.
