How to clean firewall wiring harness?
Old Dec 2, 2004 | 01:02 PM
MrNuke's Avatar
MrNuke
Default How to clean firewall wiring harness?
I was told to clean the contacts between my firewall harness connectors behind the battery, as that may be the culprit in my flickery tach/lcd display.
I removed my battery and can get to the harness, but the only thing I can remove is a plastic cover over the top set of wires, and can't find any ways to actually disconnect the whole wiring harness to clean it.
Anyone has any Ideas?
BTW I have an '85 vette, but the harness/firewall should be pretty much the same as newer ones too IMO.
Thanks in advance
Old Dec 2, 2004 | 02:29 PM
bogus's Avatar
bogus
I always thought those harness connectors came apart...
I don't have the right book in front of me, so hopefully someone will chime in, or, I will find and check there.
Old Dec 2, 2004 | 05:21 PM
MrNuke's Avatar
MrNuke
My Haneys manual does not show it at all..
Old Dec 2, 2004 | 06:21 PM
mash557's Avatar
mash557
There should be a bolt/screw in the center of the bulkhead connector on the firewall side. Just went out and looked at my 86 and that is how it is.
Old Dec 2, 2004 | 08:42 PM
MrNuke's Avatar
MrNuke
Ahh... thank you!! I finally got it.. What a PITA it was to get to that screw. Wouldn't have seen it if I wasn't told it was there.
Ok so I got the exposed contacts, I cleaned the contact parts and left the dark sutty weather protection goop inside. I used a small wirebrush to lift the goop off the exposed contacts and hopefully this'll make better contact and solve my issues.. we'll know tomorrow..
Thanks everyone...
Old Dec 3, 2004 | 09:57 AM
rick lambert's Avatar
rick lambert
Usual problems here are water intrusion, a greenish or whiteish look. At any rate when you're thru-use some spray undercoating to seal the top and sides of the harness connection to seal it from future water intrusion (something GM screwed up on according to Killebrew) also make sure the cowl drip tube is not directly dumping onto the wire harness-another GM screw up.
Old Dec 3, 2004 | 10:06 AM
MrNuke's Avatar
MrNuke
Thanks for the info. There was no whitish or greenish discoloration, but haven't fired the car up yet. We'll see ocne I'm done with my calls today,..
Old Dec 3, 2004 | 10:33 AM
loiq's Avatar
loiq
Old Dec 4, 2004 | 01:47 PM
MrNuke's Avatar
MrNuke
Woohoo! It worked..
No more jumpy lcd display/tach issues..
thanks for everyone's help..
Old Dec 4, 2004 | 02:47 PM
MrRenoman's Avatar
MrRenoman
I guess I know what I'll be adding to my "to do" list. Mine is flickering too.
Art
Old Dec 4, 2004 | 10:37 PM
cv67's Avatar
cv67
St. Jude Donor '05
Mine, too! Thanks for the info!
Old Dec 5, 2004 | 01:05 AM
Sam Lam's Avatar
Sam Lam
I recently cleaned the harness connector on my 89. I found that removing the battery and its holder allowed me better access to the connector. I cleaned the black gunk off the terminals using a tooth brush and xylene solvent. A rag placed under the connector caught all excess. I placed a coating of Ox-guard on all terminals before reassembly.
SAM
To How to clean firewall wiring harness?
