MAP vrs MAF in 86
Old Dec 2, 2004 | 04:52 PM
Carl Johansson's Avatar
Carl Johansson
Default MAP vrs MAF in 86 ZZ4 compatability?
Just a quick question guys - I know it's been answered before but I can't find it.
Does a stock 86 have MAP of MAF?
Thanks for the posts indicating that I have MAF - so how will that work if I put in a ZZ4 and use the original intake?
Carl Johansson
Old Dec 2, 2004 | 05:24 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The MAF is the tube just behind the air filter housing and in front of the bellows; no MAP.
Old Dec 2, 2004 | 06:18 PM
vader86's Avatar
vader86
Maf
Old Dec 2, 2004 | 06:40 PM
Carl Johansson
Thanks guys,
Now how will the MAF work if I install a zz4 motor and use the stock intake setup?
Old Dec 2, 2004 | 07:29 PM
red L98's Avatar
red L98
it should work fine , i would get hold of jesse ski_dwn_it and have him burn you a chip . and it should move good . good luck
Old Dec 2, 2004 | 08:42 PM
vader86's Avatar
vader86
I see no reason it would give a problem that would be MAF-related.
Only problems will be the exact tuning of the ZZ4's cam.
Old Dec 2, 2004 | 09:06 PM
SunCr's Avatar
SunCr
I'm not sure, but I don't think your '86 TPI manifold is going to bolt up with the 113's on that ZZ4 as I think there was a bolt pattern change. The cam is different too. Might be better to get the short block or work with a builder that will give you a credit for the parts you're not going to need.
Old Dec 3, 2004 | 11:15 AM
Carl Johansson
Default TPI compatability
I already have asked about compatability of the early 86 (Iron heads) TPI with the ZZ4 - the consensus seems to be that it will bolt up.
I already have the ZZ4 and I will mate it with the Keisler engineering 5 speed (won't be in until late feb) then drop em in as a unit. I'm looking for straight forward installations - bolt on drop in.
Thanks for the help and any opinions all of you might offer
Carl Johansson
Old Dec 3, 2004 | 03:05 PM
65Z01's Avatar
65Z01
I think the issue was with two center intake bolt angles on the F-body cars from early '80s to late '80s TPI; the solution was simply to machine the correct bolt angles into the intake base.
In either case you should be fine, as even that little bit of machining (if needed) is not a big deal.
To MAP vrs MAF in 86
