Average cranking time before start?
Old Dec 5, 2004 | 07:45 PM
Lone Ranger's Avatar
Lone Ranger
Originally Posted by CFI-EFI
The cam less engine holds all sorts of performance promise. The servos or solenoids will be electronically triggered, by a computer, of course. Picture, a baby smooth idle with a 200* duration @ .050" profile, with the duration increasing with the rpms.
Servo/solenoid operated valves are the future of internal combustion engines. But it does put quite a durability task upon the servo or
solenoid. It would have to be one bullet proof unit.
In related news, I think BMW already has or is working on a throttleless engine where the rpm is controlled by valve lift or something, and that would require a camless engine as well, yes?
Old Dec 5, 2004 | 10:42 PM
bogus's Avatar
bogus
Although I've heard of the cam less engine, the starter less is new to me. I see a can of worms to work through, there. If a cylinder is poised to fire, how do you get fuel to it? Even with direct injection, there is the matter of compression. I have little doubt they'll do it. It will be interesting. The cam less engine holds all sorts of performance promise. The servos or solenoids will be electronically triggered, by a computer, of course. Picture, a baby smooth idle with a 200* duration @ .050" profile, with the duration increasing with the rpms. I can see it now: "Hey, Ski, can you burn me a chip with another 10* duration from 8000 to 10,000 rpms?" "I need to break into the nines in my commuter car."
RACE ON!!!
sequentual injection is direct, already. So that isn't an issue, what is an issue would be fuel misting in a dry cylinder. But if you view it like a gun going off, that's how it would work. All it has to do is create enough piston velocity to get the crank moving.
If I remember my trivia correctly, most engines stop at the same point, when shut off. This means, they could stop the engine at a specific point. Then, force some compressed air into that cylinder, fuel, and bang, started.
This works if they use a pneumatic valve actuation, cause there is your air pressure to fill the cylinder.
Old Dec 6, 2004 | 02:09 PM
Cold_B's Avatar
Cold_B
Originally Posted by Perfusion
my LT4 explodes to life the second the key is turned!
Old Dec 6, 2004 | 02:55 PM
CFI-EFI's Avatar
CFI-EFI
None of the gasoline, sequential injected, engines *I* am are of are direct injected. The injector is installed in the head end of the intake manifold and is aimed at the back of the intake valve. If a cylinder is in a position to fire, the intake valve is closed and there would be no way to make the fuel available for combustion, unless it is sprayed directly (direct injection) into the cylinder.
RACE ON!!!
Old Dec 7, 2004 | 02:46 AM
bogus's Avatar
bogus
well, that's true... I forgot the subtle difference there between sequencial and direct. my bad.
however, there are some direct injected gas engines in Japan... I think Mitsubishi has one.
What I don't see is how a Diesel could be made to start this way... hmmm...
Old Dec 7, 2004 | 07:26 AM
Atok's Avatar
Atok
Originally Posted by MrRenoman
Mine starts the same way, instantly. I can't believe it. I don't have to do anything except turn the key.
Yep, turn the key and bam, it starts almost instant. It *might* take 1 second. Stock '95 LT-1.
Old Dec 7, 2004 | 07:39 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Mine fires like new money, too!
Old Dec 7, 2004 | 07:46 AM
Nathan Plemons's Avatar
Nathan Plemons
Since I installed the LTCC, start time has increased a touch, but no more than 2~3 seconds... max.
A good friend of mine was at Dodge School (he works as an A-line tech at a Dodge dealer). They were learning about the new HEMI. However, the instructor said that Ford is working on a motor without a starter and without camshafts.
Using some form of servo to activate the valves, the starting process would be dependant on very sophisticated crank sensors so the engine computer could find which cylinder is nearest to TDC, fire it, and BAM! Engine started.
I wrote a paper on the electromechanical valve engine back in high school. At the time they actually had a Ford Ranger with a working system. The two main problems was that it was very noisy and it couldn't keep up above about 3000 RPM's. Hell that was like 6 years ago though, I'm sure they've made a lot of progress since then. Just imagine the posibilities if you could change duration and lift on the fly. You'd have an engine that could run a peak efficiency regardless of RPM. No more of this you have to trade low end torque to get upper end horsepower crap. :drool:
The starter thing is a very interesting point. I guess you could inject fuel into the cylinder, close the valve and ignite it. You won't have the compression but any combustion process is going to create an expansion. The question becomes would it be enough expansion to move it fast enough to create the necessary compression on another cylinder? The really cool part about it though is that during the starting phase you could actually hang the valves open so that you're not fighting vacuum and compression on the cylinders that you don't need it for. It would be a complicated computer program program but very neat to see it work.
Old Dec 7, 2004 | 09:25 AM
mesteffen's Avatar
mesteffen
89-L98-six speed
It starts within the first second all the time.
Old Dec 7, 2004 | 02:06 PM
bogus's Avatar
bogus
That leads to a thought I posted above, the ability to inject compressed air into a cylinder to give it compression.
if the valves are already pneumatic, then the air compression ability is there...
as for the luxury of endless valve timing, at the valve, drool is the word, yo. damn. That is just insane. So many more variable. VTEC on steroids. Could you image a 7 litre V8 with this kind of technology? 700hp, gut wrenching torque off the line, and an 8000 RPM redline. PLUS, get 35mpg on the highway.
It is not just possible, it is real.
Old Dec 8, 2004 | 06:56 AM
Atok's Avatar
Atok
Yeah, but wouldn't it be easier to just install a super-charger?
Old Dec 8, 2004 | 10:10 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Nathan my 92 fires up immeadiatly. I've always liked that for some reason.
Old Dec 8, 2004 | 11:36 AM
  #33
Kwikerthanu's Avatar
Kwikerthanu
St. Jude Donor '05-'06
Mine starts instantly, regardless, hot or cold. It's almost spooky..like it was just waiting to go.
Old Dec 8, 2004 | 01:33 PM
  #34
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
'96 CE. Cold- 2 seconds, warm, instant.
Old Dec 8, 2004 | 06:05 PM
  #35
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
The cylinder would have to be PAST TDC, or it would start backwards...then being PAST TDC means it would already have fired?
I would think this method would not be very reliable, since after sitting for several days, there would be no air/fuel mixture to ignite...?
I had read about the same starting method somewhere, but its almost unworkable. If you want to eliminate a starter motor, just combine it with the alternator...
Larry
