Radio does not turn off when door is opened...
Old Dec 5, 2004 | 03:43 PM
NE14SIN's Avatar
NE14SIN
Default Radio does not turn off when door is opened...
My radio does not turn off, and the interior lights do not come on when I open the driver's door. If I open the passager door, the radio does turn off and the lights come on. It used to work normally until a month ago, and now I have to open the passanger's door to get the alarm to arm and the radio to turn off. Any suggestions?
Old Dec 5, 2004 | 03:49 PM
tempest's Avatar
tempest
there is a plunger "door adjar" switch on the end of your door. it gets stuck often. when i had the problem i just put WD40 on it, jiggled the switch, and it did the trick. might want to take the switch out and give it a proper cleaning if you want to do a better job.
Old Dec 5, 2004 | 03:52 PM
bogus's Avatar
bogus
worst case, there is a courtesy light controller that MIGHT have failed... but that is a rare occurance.
To Radio does not turn off when door is opened...
