clutch parts
Old Dec 5, 2004 | 10:36 PM
Clemson Vette's Avatar
Clemson Vette
Default clutch parts
i'm getting new clutch parts for xmas. i mean the master cylinder, slave cylinder, and the other stuff that i should replace when working on the hydralics. so waht all should i replace exactly? and where do you get this stuff? i wish i could upgrade engine but tranny has to work so theres my xmas gift.
stuart
Old Dec 5, 2004 | 10:45 PM
bogus's Avatar
bogus
whatever you do, don't get the GM kit!!! They are having HUGE problems with it.
If you replace, get the slave... that is more than likely the problem.
Old Dec 6, 2004 | 12:19 AM
ninetyfivevette's Avatar
ninetyfivevette
Bogus- where would you recommend getting the parts? I will be getting new master/slave cylinders depending on condition of the used units coming with the trans I bought.
Old Dec 6, 2004 | 12:33 AM
Dads90's Avatar
Dads90
Try Rockauto.com for clutch parts master, slave, Im not sure about the hydraulic line. wagner brand slave #107311
Old Dec 6, 2004 | 07:47 AM
Aaron71771's Avatar
Aaron71771
Are you just replacing the hydraulic system (master/slave) or the clutch assembly as well?
Old Dec 6, 2004 | 12:06 PM
Clemson Vette
just hydralics master, slave, and the line between the two i think. no clutch parts tho. all that is good.
To clutch parts
