forced lockup
Old Dec 6, 2004 | 05:31 AM
85blkrose's Avatar
85blkrose
Default forced lockup
i read a post in another section that didnt deal with this but mentioned
it and for the life of me i cant find it. some how you jumper pins to
force converter lockup in 2nd and 3rd @wot. anyone help me on this
would like to try ths out. not all the time cause i am sure its hard
on the tranny. just want to experiment a little
Old Dec 6, 2004 | 11:13 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Torque Converter Lockup Switch
By Ed Maher (esm120@psu.edu)
The Parts
1. A length of small wire (~18->22 guage)
2. A toggle switch
The Installation
1- Determine where you want to mount the switch. I put mine in the hole where the fuse box lid locked into. It is an easy to reach place under the dash, and is pretty well concealed, and required no drilling.
2- Run the wire from the ALDL connector (the ALDL is the thing you use to scan for codes, see below for diagram) to where you are putting the switch. This is easy if you are mounting the switch under the dash on that hush panel, and is made easier if you actually remove the screws that hold it up and pull it down for clearance.
3- You can make this temporary or permanently wired in.
Temporary: Strip off about 1-2 cm from the ends of the wire.
Insert the wire into terminals A and F (the top right and top left holes respectively).
Permanent: Unscrew the ALDL from the dash and lower it so you can see the wires behind it. Splice your wires into the top outermost wires.
4- Hook the other ends of the wire to the 2 contacts of the switch and mount the switch.
5- Go for a ride. First to make sure it has a good connection, start in first gear with the switch ON and rive away normally. When it shifts into 2nd, it should pull the rpms down real low and bog. If you tap the gas, it should feel jerky and locked like a stick car (while rolling in 2nd with the switch on I can chirp the wheels by just tapping the gas--who says carbs have no throttle response). If it doesn't feel any different, then your connection is bad at the ALDL, or you have the switch OFF. Try flipping the switch again and if that doesn't fix it, play with the wires at the ALDL to get a good connection.
-JRC-
Old Dec 14, 2004 | 01:21 PM
85blkrose's Avatar
85blkrose
thanks for the info. it was exactly what i was lookin for
To forced lockup
