fan relay connector
Old Dec 7, 2004 | 01:45 PM
corvettemaster's Avatar
corvettemaster
Default fan relay connector
where can i find the connector that plugs into the fan relay (the one located under the cruise control module on 85-87 vettes...that i know of)? mine acutally melted into the relay. so i need the relay, and connector. i can find places that sell the relay but have been unable to find the connector. Or is there a better way to do it? like wire up a manual fan switch?
Old Dec 7, 2004 | 02:21 PM
rick lambert's Avatar
rick lambert
have you tired the dealers yet?
Old Dec 7, 2004 | 02:29 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Try here:
http://www.haywireinc.com/
Old Dec 7, 2004 | 02:39 PM
CFI-EFI's Avatar
CFI-EFI
I wouldn't go purely manual. Find the connector, using the above help, then consider if you want a manual option. I have a three position switch. 1.) Fully automatic, 2.) Constant on, and, 3.) Cannot come on.
RACE ON!!!
Old Dec 7, 2004 | 05:59 PM
Strike3's Avatar
Strike3
I have an 87 and just replaced mine. Corvette Central and Ecklers have a kit which includes the connector and relay.
Ecklers part number 30974 $16.99
Corvette Central part number 244213 $17.95
I think their shipping charges are differant so the prices are not the only consideration.
Old Dec 7, 2004 | 06:56 PM
corvettemaster
Thanks! Upgrading to the newer 88+ relay will be great. It turns out that after shipping charges to my address, Corvette Central is about $1 cheaper. Not enough to worry about though. I've ordered from both before, but I'll probably go with Ecklers. Thanks for the part numbers!
Old Dec 8, 2004 | 10:09 AM
MrRenoman's Avatar
MrRenoman
JUnk yard. Many 80's GM intermediate cars use this connector for fans and possibly other functions. They disassemble/reassemble very easily so you may be able to re-use some of your wiring and wiring connectors.
Art
To fan relay connector
