Please post your alignment specs and intended purpose
Since he's a friend he'll gladly align the car to whatever specs I want. I figured that the stock specs are probably a little conservative, others have mentioned that they have custom specs. I'm looking for aggressive handling while maintaining a pretty steady ride. I don't want it to really dart left to right if at all possible. Long tire wear is a must too.
Several people have said they have good alignment specs that provide improved handling over stock while still providing even tire wear. Let's hear them please.
Thanks guys.
zero tow front
1/8" toe in per side, rear
car is lowered, use Kumho MX 275's front and rear on stock wheels, ES master kit poly bushings. revalved FX3 shocks with Doug Rippie poly bushings, stock sways and stock sway bushings, stock springs.
intended use: racetrack
street manners: can be a little darty and follow the ruts on poor roads highways, but it's a minor annoyance. It sticks to the curves enough to get me thrown in jail, or worse. Highway off/on ramps can be taken faster then my nerve will allow.
race track: pleasently surprised. ran 2:30's or so at Watkins Glen, first time on any race track. I let an experienced (with porsches) friend of mine take it out one session, and he was turning low 2:20's.
my settings may be a tad too aggresive if you're not going to take it out on a race track.
I think he maxed out the caster, negative camber in front & back, and a touch of toe in (more in the back).
For auto-x most people run toe-out in front, but it makes for a skittish car.
It highways very well and eats up tight turns, oversteer has been reduced a lot. I haven't raced it yet, that'll have to wait until spring.
If you want exacts IM me and I'll get em tonight.
Agressive handling alignment and long tire life are at opposite ends of the spectrum. If you get enough camber to really help cornering you will also get tire wear and maybe lose a little hookup too.
I think that with stock alignment and poly sway bushings you will have nicely improved cornering properties. Also you can trim handling a little through tire pressure variation.
http://www.vbandp.com/instructions/h...ruct/align.htm It made a big improvement in autocross over the OEM specs.
On the street, I have not had any issues with it at all. I haven't run this setting for more than 500-600 miles at this point so I cant really tell if there is any increase in tire wear at the edges. The best thing I have noticed is that turn-in is much easier and there is much less understeer.
-.75 camber front 1/16-1/8 total toe in. As much caster as you can get.
-.50 camber rear 0-3/32 total toe in.
I do my own alignments and this set-up is okay on the street. I also club race 3-4 events a year with these same specs.
Anymore (on the camber or less toe) and the car will be darty and IMO useless on the street.
Steven.
P.S. my car is a 1992
http://www.vbandp.com/instructions/h...ruct/align.htm....
i drive about 30 miles daily to work with no uneven wear problems. in the autocrosses i could probably use more negative camber looking at the wear.
good luck on your bushing install Nathan. lookin' forward to seeing some pics of the install from ya next year.
That's a pretty good baseline for a street car, though I personally wouldn't do zero toe in the rear. I'd go around 1/8" total toe-in on the rear.
Front (approximate values):
Camber -0.8 deg
caster 6.3 deg
toe (inward total) 0.05 inches
rear
camber -0.5 deg
toe (inward total) 0.10 inches
Ride height: (ground to finder lip) 25 3/8" front; 26 3/8" rear
Tires: 275x17 and 315x17 Hoosier R3S04: 30#cold front; 26# cold rear
Front: Toe: 3/16 out. Camber: LF neg 2.70; RF neg 2.50. Castor: +7.5
Rear: Toe: 1/16 in. Camber: LR neg 2.0; RR neg 1.75.
Bumpsteer Front:.008 out/inch. Rear: .002 out/inch @+/-1" bump/droop
LF: 710# RF: 685#
LR: 733# LR: 705# sj
Daily Street
Front
toe-1/32" in
camber 0* -+
caster 5* to 7* pos
Rear
toe-1/8" in
camber 0* -+
Advanced Street
Front
toe-0" in
camber .25*-
caster 5* to 7* pos
Rear
toe-1/8" in
camber .5*-
Autocross baseline
Front
toe-3/16" out
camber 1.5*- (or as much as you can get)
caster 4*to 5* pos
Rear
toe-1/16" in
camber .75*- to 2.5*-
Hope this helps
