electrical short
Old Jan 13, 2005 | 01:05 PM
montecarlo4's Avatar
montecarlo4
well i have put up with this prob for long enough
so i put a test light on the fuses with car off and ignition off
and several fuses lite up, so now i need to go back and check what each fuse goes to and fix them? correct
i will post he affected fuses 2morrow as i didnt write them down, cus i didnt think there would be several
matt
Old Jan 13, 2005 | 03:07 PM
ALLT4's Avatar
ALLT4
matt
I would hope you have voltage (light) on some of the fuses, after all some things are still powered even with the ignition off. I think you're going down the wrong road there.
What I would do is make sure I had a well charged battery installed. Measure it's voltage not hooked up to the car, remember that number you get. Hook up the battery with the car off and measure it again. If there is a signifigant drop keep the meter on the posts monitoring the voltage as you pull fuses looking for a big jump in voltage or close to your read on the battery unhooked.
If you don't think it could be through a fuse you'll have to try looking other places that might have hidden fuses (links) running elsewhere in the car. You may need a manual for this one.
There's a lot of different ways to find a current draw but that might be the easiest for you.
Old Jan 14, 2005 | 02:50 AM
smacko's Avatar
smacko
Got a problem when i turn the key on in my 84.
with key off, the batt with voltmeter reads 11.8ish
and when i turn the key to accessory drops to 9.8ish,
i have pulled each
fuse one at a time, no difference, i have recently replaced the
starter, beside the starter solenoid, what else could it be?
what should i look for?
thanks
matt
As per a post of mine recently (Somewhere); check also interior lights AND check that the light in your centre console 'glove compartment' is GOING OFF - They use a mercury switch and I have recently had a battery drain overnight due to a faulty mercury switch in my '85, causing the hood lights to be ON when hood was closed (Although that doesn't sound like your particular situation). One last thing - check ALSO (I'm not sure if '84's have them) that your spare tyre light (Above spare tyre) is not staying on...Again though; I think they'd stay on all the time rather than only in accessory mode.
To electrical short
