weird timing???
RACE ON!!!
Don't forget to disconnect the battery for about 30 secs. afterward, to clear the code.
RACE ON!!!
what kind of timing light are you using ?
if your using a light with a advance **** make sure its on " 0 " degrees
good luck
6spd,
Give me your real name and I will be able to look to see exactly what it should be at idle, with the ESC connected.
We all need to step back and get on the same page. Here are the guidelines that some are confusing. With a 91 bin the following apply.
Base timing of 6* - this is what you set with the ESC unplugged.
With the ESC plugged in you should be ~20-25* timing at idle, ~800-1000 RPM. WHen you give me your name, I will be able to check it for sure.
Suppose its 20* for idle at operating temp etc. What this mean on a 91 bin is the following.
You have a base of 6*, then the ECM is adding an additional 14* to achieve the total 20* that you should now see if you have a timing light that you can dial up till it reads 0* on the balancer.
Base 6* + 14* ECM = 20* total at idle.
Hope we all are on the same page now.
Now let me say if you increase the base timing to 8*, then you will have
base 6*+ additional 2*+14* ECM = 22* total now. BUT THE ECM WILL ONLY THINK ITS 20* and report that out on the laptop!!!! That is due to the parameter referred to as "initial base timing". In other words with the intial base timing your telling the ECM what your setting the base timing to. If you deviate from that, then you must add or substract the amount you deviate to your programmed timing.
So, looking at what you have supplied here for data, I would say the following. Regardless of your balancer is off or not. If you infact set it to 6* base with the ESC unplugged, when you plug it in you should see a min of 14* added to that base. Otherwise your ESC is not working properly and your not getting the advance that you should be. It *MAY* be adding more but I highly doubt less than 14*. When you get me your real name, which is what I file the bins under, I will be able to determine a much closer number it should be adding.
But from what I am reading, if you are setting the base to 6*, then plugging in the ESC, and your only getting a total of 12*, then something is definately NOT right with the ESC/ECM.
Few things to be sure of:
1. verify that your setting the base timing at BTDC and not ATDC. Cause that would put you close to what your seeing.
6* ATDC + 14* advance would be ~8* BTDC
If I have the advance at idle set to ~25* you would be at 13*
2. That your getting the same readings with a different light.
3. That your for sure on #1 wire.
4. Not sure how to figure this out, think you should still get the same additional advance of about 12* even if your distributer is in wrong. That is too much thought to figure out.
Well that is about all I can think of now. But the "Advance" when you plug in the ESC should be about 14* min. Maybe more depending on where I have the base timing set.
My guess is that you have it at 6* ATDC, then the ECM is adding about 19* advance which is then putting you at 12* BTDC. That is the exactly scenerio you would have if I have the timing at idle set to 25*.
Can you see the markings on the pointer? Are you sure its on right?
Get back to us.
So with a base timing of 6* you should be seeing a 20* incremental increase with the ESC plugged in. IF your not, then your ESC or ECM is NOT reading correctly. Be sure to check the light also to rule that out. You have to attack the problem systematically or you will miss something. DO NOT ASSUME anything is right.
How is the car running other than this variable? Do it feel better if you increase the base up to say 12* (take it easy testing it), or does it feel better back at 0* base?
Anyways you should see that increase with the pluggin in of the ESC.
Can you take a digital picture of the timing pointer/indicator for us. Show us where your lining up the marks.
RACE ON!!!
You leave your EST wiring disconnected all the time, correct?
So how does that affect your timing?
RACE ON!!!
You need to go back and read and re-read my post that I explain what *should* happen.
You are NOT getting the right amount of timing added to by the ECM. Why, I can't be sure of.
If you have the base set at 6* and you plug in the ESC, clear the code with unplugging the battery, restart the car, it should add about 19* more timing!!!!! 19 Degrees not 6 degrees like your reporting.
What happens if you rev the motor a little with while reading the timing mark?
Its very tough for us /me to conclude exactly what might be wrong.
Perhaps if you go point by point listing like 1., 2. 3. and so on in VERY GOOD detail what your going when you read the timing - we can conclude what exactly is happening.
I still think your setting the timing to 6* After TDC and then when you plug it in, you are getting the full amount of timing, but it lands you at around 12 to 13* depending on RPM.
Is the 12* your reading at idle with ESC plugged in the SAME side as the 6* base? Or is it on the other side of the pointer? It it the upper side or the lower side of the pointer?
