Oil Pump Shaft
Old Dec 11, 2004 | 04:14 PM
PMARTINEZ92126's Avatar
PMARTINEZ92126
Default Oil Pump Shaft
I have an 86 vettte and Im reinstalling the distributor. Im using a large screwdriver to turn the oil pump shaft so I can get the rotor to fire off on number one. I noticed that i can wiggle the oil pump shaft around with the screwdriver. This is a new motor that hasnt been fired off yet. Is there supposed to be play with the oil pump shaft or did something come loose. I have a call into my machine shop but its the weekend. Its a high volume oil pump. I primed the engine and it oiled up good so i was wondering if this is normal play
Old Dec 11, 2004 | 04:24 PM
CFI-EFI's Avatar
CFI-EFI
Those suckers are as loose as a goose. You don't have a problem. If you look inside your distributor gear, you'll see how it gets stabilized on the top end, with the distributor in place.
RACE ON!!!
Old Dec 11, 2004 | 06:22 PM
truxell3's Avatar
truxell3
7th Gear
RACE ON!!!
Old Dec 11, 2004 | 07:04 PM
Muffin's Avatar
Muffin
THe oilpump drive shaft is coupled to the pump by a sleeve, metal in the case of a hi-volume pump. As stated the fit is best described as loose as a goose. Don't worry about it.
Old Dec 11, 2004 | 07:41 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
RACE ON!!!
Ditto, no worries! For just a few bucks, you can go for a hardened shaft w/ a steel coupler (instead of plastic) and I hope your builders installed this. If it's a stocker or mildly modified engine, you'll be fine either way.
To Oil Pump Shaft
