Dual Mass Resurfacing
Old Dec 12, 2004 | 03:48 PM
tvetta's Avatar
tvetta
Default Dual Mass Resurfacing
Guys have any of you heard of www.dualmassinc.com.
They can resurface your dual mass for $200.
Have any of you used them. They are also willing to offer group discounts!
Old Dec 12, 2004 | 05:15 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Originally Posted by tvetta
Guys have any of you heard of dualmassinc.
You will have to seek approval from an Admin before you can set up a GP.
Old Dec 12, 2004 | 07:13 PM
bogus's Avatar
bogus
Check the disclaimer at the bottom of their site:
"Warning: The resurfacing process performed by Dualmass Inc. is not recommended by the original equipment manufacturer. By using DualMass Inc. services and not buying a new flywheel from the original equipment manufacturer the customer assumes full responsibility for their own actions. DualMass Inc. WILL NOT be held responsible for any damages to persons or property up to and including death."
Emphasis added.
Old Dec 12, 2004 | 07:38 PM
GMJim's Avatar
GMJim
Iv'e machined three of these flywheels. One was a ZR1. The clutch and flywheel are manufactured by Luk (at least the C4's are).
http://www.lukusa.com/products/index.phtml?page=dmf
Though they don't recommend resurfacing (they also sell new ones). If it is within backlash specs and If you find a shop that will take the effort to clamp the flywheel down securely and remove small amounts at a time, this can be done easily. I don't recommend it be done more than once and no more than .040" be taken off. If I were to replace the flywheel I would not use a new Dual Mass. I would be calling Doug Rippie and get a solid flywheel. Less money and no worries. The first gear idle rattle is not nearly as bad as what it's reported to be.
Jim
Old Dec 12, 2004 | 08:52 PM
Strick's Avatar
Strick
Jim
It's all dependent on the tranny's condition. More wear-more noise.
Old Dec 12, 2004 | 09:20 PM
tvetta's Avatar
tvetta
Jim
Who is Doug Rippie? What is his number?
Old Dec 12, 2004 | 09:23 PM
GMJim's Avatar
GMJim
He's right up there with Lingenfelter and Callaway.
http://www.dougrippie.com/
Jim
Old Dec 12, 2004 | 09:27 PM
GMJim's Avatar
GMJim
Strick
Use Redline MTL fluid. Better shifting quieter operation and easier on those ZF synchros.
Jim
Old Dec 12, 2004 | 11:45 PM
bogus's Avatar
bogus
GMJim - The flywheel and clutches are exclusively made by Valeo.
All pressure plates are Valeo... aftermarket then tweeks as needed.
The friction discs come from multiple sources - Luk, Valeo, etc.
The downside of turning one of these flywheels: If your clutch lasts a normal life, lets say 100k miles, you only have 20k miles left in the flywheel. I don't see a reason to do this. If you race and blow the clutch at 50k miles, who's to say the flywheel is structurally sound?
The last time I checked, the flywheels from DRM are unavaliable. They bought a stash of F-Body flywheels, then turned them down the required .090. I contacted them 2.5 years ago, and they were out of them, with no plans of getting more.
The bottom line, just buy an F-Body flywheel, and have it cut down .090.
What is needed is a rebuild facility. Someone who can cut the friction surface, then replace the springs and ball bearings inside.
This would effectively double the lifespan of the flywheel.
It would make sense to disassemble the flywheel, resurface the friction surface, then reassemble with new internals.
This would be worth $200.00.
Old Dec 12, 2004 | 11:51 PM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
I talked to the guys at my local shop and they have resurfaced the dual mass flywheels by spot welding them before surfacing them then grinding off the spotwelds afterwards. They have had success doing this I just wanted a Fidanza due to the weight saving = rwhp theory.
Old Dec 12, 2004 | 11:52 PM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
Strick
Jim
This is on my to-do list for the winter!
Old Dec 13, 2004 | 06:50 AM
Strick's Avatar
Strick
Strick
Jim
Thanks for the tip, Jim, but I've had lots of luck with the good ole GM synthetic fluid. I still have the dual mass and everything is nice and quiet and shifting is great, especially with the Hurst.
Old Dec 13, 2004 | 03:38 PM
GMJim's Avatar
GMJim
It was my understanding that Valeo was a Luk International company. All of them are stamped Luk??? I must confess that I would machine my own flywheel but I usually refrain from recommending it to customers. You never know what they're going to subject them to. However, most of the Corvettes I end up putting flywheels in usually get a Doug Rippie solid flywheel, the original is usually only slightly worn and takes only a light cut to clean them up so I keep them as spares. No complaints about noise with the solid. I really can't see the sense in welding a F body flywheel and cutting it down when the aftermarket now has many new choices. I have done a few diesel trucks with dual mass F/W's that are $2000.00 plus bucks and those guys wish there was an alternative because those are usually junk when they come out. Anyway I hope the dual mass flywheels soon go the way of the DoDo Bird.
Jim.
Old Dec 13, 2004 | 04:17 PM
bogus's Avatar
bogus
Perhaps Luk owns Valeo, but according to Bill & ZFDoc, it is all Valeo... every part I have ever bought says "Valeo" on it.
As I said before, the DRM flywheels are just f-body pieces, cut down .090. They are out of stock the last time I checked.
I am afraid that the DMF's are here to stay. The new 350Z has one...
To Dual Mass Resurfacing
