hp gain
Old Dec 13, 2004 | 07:50 PM
bops90's Avatar
bops90
Default hp gain
What would be the hp gain if any by swapping out just the mufflers with free flowing ones? Thanks Mark
Old Dec 13, 2004 | 09:47 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
I can not tell you what the exact HP gain is for just mufflers... but I did Hooker AeroChambers and noticed a difference on the butt-o-meter. I believe it was Magnaflow exhaust that said the mufflers were the only restrictive part of the C4 exhaust... so that was the only thing I replaced.
Old Dec 13, 2004 | 10:41 PM
BowTieBlood's Avatar
BowTieBlood
I wouldn't expect too much, but you'll probably get a little.
Old Dec 13, 2004 | 10:44 PM
Irishpilot03's Avatar
Irishpilot03
I cut out my resonator and went with an X-pipe, and I have the Borlas on. I noticed some hp gain, but not what the aftermarket manufactures quote, but it sounds quite a bit better!
Old Dec 13, 2004 | 11:21 PM
SLOWRIDE's Avatar
SLOWRIDE
Should sound a lot better. Depends on which ones etc. I would not expect a real big gain. Go for it. Good Luck
Old Dec 13, 2004 | 11:23 PM
mikey whipreck's Avatar
mikey whipreck
depends what year your talking about...
I would say the earlier the C4, the greater the gain by switching to performance mufflers.
maybe somewhere from a 10 to 15 hp gain? just a guess
Old Dec 13, 2004 | 11:24 PM
kwik_ta's Avatar
kwik_ta
what muffler are you planning to go with? You are kind of restricted to size in the space you have to work with... my tips stick out about an inch from the stock location now... but I think it looks pretty cool. Make sure you get the right measurements so you don't end up with the 'ricer' look.
Old Dec 13, 2004 | 11:44 PM
bops90's Avatar
bops90
Thanks for the input, I was thinking Borlas, dont want it real loud though.I saw a place on line 435.00 cat back think I might go that way.
Old Dec 14, 2004 | 01:53 AM
88BlackZ-51's Avatar
88BlackZ-51
5-8chp prob...
Old Dec 14, 2004 | 09:45 AM
kwik_ta's Avatar
kwik_ta
I'm confused on how you came to that conclusion when the original question asked hp gains with "just mufflers"? That is a good price so by all means get the Borla!!! I just want to add that I have $120 wrapped up in 2 Hooker Aerochambers and I think they will flow just as good.
Either way, I don't want you to think I'm criticizing your choice... I'm just confused... it happens a lot.
Old Dec 14, 2004 | 11:37 AM
bops90's Avatar
bops90
Cris,It was a bit confusing,I guess the question is would you get any more hp going with a 2 1/2 cat back system rather than just changing out the mufflers i think the original system is 2 1/4
To hp gain
