LT4 Heads question.
Old Dec 14, 2004 | 04:53 PM
ALLT4's Avatar
ALLT4
Default LT4 Heads question.
I'm picking up my 96 LT4 this weekend and was doing some thinking. I know a dangerous thing.
You see I have this LT1 with all LT4 top end sitting in my garage a buddy bought a few years back. He keeps saying he's going to stroke it and do it up, I think it's all talk. Anyway I'm wondering if the heads are worth sending out for further flow work or if a new set and what kind would flow even better than stock.
Probably has been answered here before but I'm lazy and don't feel like searching hundreds of posts. Plus fresh information is always better I think.
Here's what's sitting growing mold in my garage.
Old Dec 14, 2004 | 04:56 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
The LT-4 heads can be set up to flow comparable numbers to that of some reputable aftermarket heads. I'm stumped though... you are getting an LT4 right??? And the motor in your garage is and LT-1 with the LT-4 conversion... which motor are you planning on tearing into?
Old Dec 14, 2004 | 05:03 PM
ALLT4's Avatar
ALLT4
Instead of having my car down for head work, the ones on the stand could be sent away for work then just swapped onto my car with little down time. It beats tearing the motor down and opened up for a couple of weeks or whatever it would take to have them done.
If LT4 heads can't be made to flow much better than what they do stock the whole idea isn't worth it.
Old Dec 14, 2004 | 05:40 PM
MYCoupe's Avatar
MYCoupe
A good porting job will do wonders for the LT4 heads. Check out this thread for LT4 flow numbers. Maybe he will still honor the groupbuy price. You can at least ask.
Old Dec 14, 2004 | 05:59 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
The LT4 heads can be made to flow more than you could ever practically use on the street. And this guy is good, ask me how I know!
Old Dec 14, 2004 | 06:04 PM
SPEED750's Avatar
SPEED750
I would run the part numbers on that motor in storage. I'm not sure it's a LT4. The intake looks like it has red overspray inside it, all LT4 intakes are painted from the factory with no overspray. The conversion kit also comes with full roller rockers, that motor has stamped steel rockers. I would check it out before sending any parts off for modding.
Old Dec 14, 2004 | 06:10 PM
Corvette Kid
Also, LT4s don't have an EGR. Although I don't know if their intakes have a provision for it that's blocked off, or no provision at all.
Old Dec 14, 2004 | 06:21 PM
FD2BLK's Avatar
FD2BLK
I would get the cast #s and make sure those are LT4 heads and not just a LT4 intake. Look at the rockers, no LT4's came w/o 1.6 R/R's on 10mm tapered studs that regular 3/8 ball rockers would not fit on, well and work any way.
Old Dec 14, 2004 | 06:29 PM
StealDads67's Avatar
StealDads67
The EGR has a block off plate on the LT4 intake
The LT1 and LT4 intake are not interchangable due to the raised runners of the LT4.
He said it was a conversion, so just because it doesnt have roller rockers doesnt mean it doesnt have the LT4 topend. But seeing the overspray inside the manifold would make me think twice. Def check the head casting number and make sure you have what you think you have.
Old Dec 14, 2004 | 06:37 PM
ALLT4's Avatar
ALLT4
If someone painted that manifold red they went through great pains to make it look real and what would it benefit them to be found out a fraud?
As for the heads, the guy did say he just threw his old stuff on them and lost interest in the project. It all could be fake for all I know right now. I'll take some detailed pictures for you all. What should I get shots of to clear things up?
Old Dec 14, 2004 | 06:58 PM
StealDads67
LT4 heads and intake are worth alot more then LT1
Take a picture of the top of the head by the rockers, there will be a casting number, Should be on teh passanger side towars teh front of the head If im not mistaken
EDIT... actually you dont need to take a picture, just copy the number down and post it
Old Dec 14, 2004 | 07:27 PM
ALLT4's Avatar
ALLT4
It was a good idea anyway... Looks like my buddy got ripped, I thought that whole purchase was a bad idea from the get go. Oh well maybe I can still talk him into stroking it, he does have a '95 and why not give it a shot. I know if I had a spare motor sitting around collecting dust I'd be doing something with it.
Old Dec 14, 2004 | 08:38 PM
FD2BLK's Avatar
FD2BLK
Sort of, the LT4 intake will bolt up to the LT1 heads, some F-body clowns have done it. The problem is the runners don't line up as they should because of the raised runners like you mentioned but it will bolt in place and look fine from the outside. Went outside to get the #s off my intake and the cast # for thr LT4 intake casting number 12550631, it is in the center of the intake on the pasangers side
Old Dec 14, 2004 | 08:42 PM
FD2BLK's Avatar
FD2BLK
Looks like your budy got screwed.
10207643...94-96...350..........Gen.II LT1, aluminum, reverse flow cooling
10239902...96-up...350..........Gen.II LT4, aluminum, reverse flow cooling
http://www.ajf36.com/casting_numbers.htm
Old Dec 14, 2004 | 11:11 PM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
that really sucks
the first thing I noticed was the rockers and I'm thinking why in gods name would someone buy LT4 heads and intake for big $$ and then put on some pos LT1 rockers? Well I guess my question is answered! tough luck man
Old Dec 15, 2004 | 11:18 AM
ALLT4's Avatar
ALLT4
Really, I could care less. It's my friends motor, he bought it sight unseen on E-bay. He only paid a G for it and really just wants a seperate motor to build this winter. Then come spring just drop it in and sell his old one.
I'll have my REAL LT4 Vette this weekend! Talk about a long week it seems.
To LT4 Heads question.
