what should i do for budget performance upgrades.
Thank you all for your responses , they were all very helpfull i apprecciate all the experience and knowledge . Thanks and Happy Holidays!!!!
Where do you live? If you live in a state without emissions testing, ditch the pre-cats ONLY. Leave the main cat.
Those will perk up the equation a bit.
Heads, cam, gears, converter, stroker, supercharger, and nitrous is the only way you are going to go fast. oh yeah and get rid of the TPI.
If you only have $800 i would do nitrous.
As for GMHTPs testing, is that using an airfoil? or one of the TBs equiped with an airfoil?
L98? with that budget- buy yourself a new exhaust system...
You'll spend probably all of the 800. But if you do the work yourself You'll be able to come in under budget, and have a HUGE (anywhere from 40-60 HP i'd guess) power gain.
LT headers, true duals, and performance mufflers...
Yes you can buy all that for WELL under 800...
at least that's what I'm going to do with my '85 L98...
The filter, air foil, and smaller items mentioned above will help slightly- bit by bit.
Stay away from NOS... IMHO
"Next on the modification list was the addition of a Hypertech chip. This netted another two tenths and a 14.10 ET, but Hess wasn't finished. He also added a throttle body air foil, an underdrive crank pulley, installed a shift kit and a new set of plug wires. With the stock torque converter, 3.27 gears in the 9-bolt rear and still on radials, the black Poncho improved to 14.00."
All for .10?
The rest of the story:
http://www.gmhightechperformance.com...ula/index.html
All for .10?
For performance mods in your price range I suggest:
Intake - 10-15chp:
-SLP ram air intake with K&N, $120 from SLP
Exhaust - 15-20chp:
-FlowMaster Force II cat-back, $380 from Summit; or you might price out muffler elims from MAM
-2 1/2" mandrel bent front Y, $199 from MAM
-Catco cat, $55 from Summit
Cooling - 10chp:
-160det T-stat from Auto Zone & manual fan sw from Radio Shack. If your Vette has the booster fan in front of the radiator, just get a 160deg aux fan switch and use my C4 tech tip to wire it into the main fan.
-TB coolant bypass, parts from Auto Zone
Ignition - 8chp:
-cut back stock style AC Delco spark plugs gapped to .035"
Tuning - quicker throttle response:
-bump TPS base voltage to .67Vdc at base idle (450rpm)
-bump base timing to around 8-10deg BTDC
Weight Reduction: (100lbs = 10chp or 1mph & .1 sec)
-lose the spare & jack, 40-50lb saving
-cruze with 1/3-2/3 tank of fuel, 60lb saving ave.
That should eat up most of the $800, keep you occupied, teach you quite a bit about your Vette and net some nice performance gains. If you get the chance, take your Vette to a drag strip before these mods and get some time slip numbers; then you can go back after the mods to see actual gains. And these mods will give you a chance to plan where you want to go with performance and not have to undo anything.
Bogus is right about the intake, it's cheap, but it's the least effective.
Exhaust will be huge for your engine. I'm sure you can get some nice mufflers off ebay cheap.
Nitrous is by far the best bang for the buck, your engine has so few miles on it, I would think it would hold up to nitrous fine. Just keep the shot low, 75-100. Don't get greedy, 75 hp is a lot considering you car has 265 chp (or so); especially what it would cost to add 75 hp using bolt ons. But you can't autocross with nitrous and you have to fill the bottle (the more you use, the more you pay).
Good luck.
I never put headers on my 85 so I don't know what they cost, but between them and your cat back you'll be outta money. I know the car will breath a lot better.
Several guys on the forum have run 13s with all the free stuff and a cat back.
