I just returned from Dyno Day at TT Performance in Saddle Brook, NJ; even with adjusting my AFPR I could not keep the A/F ratio at WOT below14:1. It would drop from 14.7:1 when he went to WOT at 3,200rpm but climb back to 13:1 by 3,600rpm and was up to nearly 14:1 by 5,800rpm.
The best numbers were:
233rwhp & 289 ft-lb
Which is 10rwhp off my prior pulls of 243rwhp & 308 ft-lb.
So I'm thinking fuel delivery at WOT is not up to par and wonder which of the three elements (injectors, regulator or pump) is most likely the problem, the filter is about 1yr old so I don't think that is the source of problem. I've done a resistance check on the injectors and all pass.
Has anyone had a similar problem and can come with the solution??
233chp & 289 ft-lb
Which is 10chp off my prior pulls of 243chp & 308 ft-lb.
weird jimmy! you are down just like u thought.....you are down a bit in the ft/lbs, huh!! but still doesnt compute to the loss of 3 tenths.....
233chp & 289 ft-lb
wait a sec, 233CHP? that's it jim, huh!!! 200 at the wheels? did u post that properly?
A fuel pressure check under the same conditions could eliminate the pump and regulator, if they're not the cause. Can the injectors Ohm out OK and still be lazy?
Thanks Rick my bad; I've corrected it to RWHP. But you are right, peak power was indeed down for the season, as I saw from trap speeds.
CFI-EFI, good idea. I really hate to just throw parts at a problem. Maybe on a short WOT burst with a FP gauge on the windshield I can get the answer.
BTW, I've plotted up the pull data in Excel and see that going deeper than 1" (on this set of pulls it is at 2" deep) on the siamese base gave no improvement in top end, as the 1" deep and the 2" deep pull power curves are pretty much parallel. Though that may be in part due to stock heads & cam limitations. Guess I'll have to get the fuel delivery issue resolved first and get another set of pulls to verify that.
Are you running closed loop? This is normal in closed loop. Before you change anything you should run scan software to confirm the ECM is not pulling fuel out in BLM cell 15. If it is it will pull out fuel under wot. The ECM will pull fuel out as you increase the fuel pressure. You can dump the memory every time you adjust fuel pressure but as soon as you drive it it will try to lean it out again.
I didn't have the scanner on it at the dyno but a few months ago I did some WOT runs on the highway which showed BLM cell #15 & Int both at 128. At that time I was getting a little knock retard, so I'm thinking that it may have been going lean, though the O2 readings didn't indicate such.
However, that is another item to check out, thanks.
I'll have the scanner hooked up when I check out fuel pressure at WOT early next year.
Thanks for the escort back onto the Pkway, it would have been "fun" finding the path alone in the dark.
Yea, now that I have some confirming numbers I need to find out what is causing the power/torque loss. I'm even thinking of contacting Matt after I collect some more data on the issue for another copla dyno pulls.
Anyway, that has to go to the back burner for a few weeks as I prep the IROC for the trip to OH and do the Holiday shopping. And thanks for the offer of an indoor working area.
I think that intake set runs about $1,200 new and maybe $700-$800 used on e-bay. As I mentioned, I would also do at least 1.6 RRs along with it though. Since you were running a little rich on the dyno, you may not even need an AFPR nor a chip for tuning.
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
I don't want to hijack your thread. But the fact that it's running a little rich it may balance out with a new intake, because I'll be pushing more air.
I think I'll start with the intake then I'll do another dyno day. See where I'm at, then headers.
Vic, if fuel pressure drops off during testing the FP will be one item on the agenda.
Jsup, maybe we can use the AutoXray to get some O2 sensor & BLM cell data at WOT and during normal driving before and after you do the intake. That will show if it has leaned out enough to warrent an AFPR with the installation of the SR.
