Match up the hoses and make sure they are the same. Lube the inside and be patient. You'll be surprised the many different angles you can come up with. I just finished mine and know the feeling.
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Always make sure the replacement hose is physically the same. Removing the fan assembly and shroud helps to offer a bit more elbow room in there too.
I have an aftermarket aluminum radiator in my 86 and after fabing up a couple of hoses using a plastic coupler that I was not sure would last long term I went with one of the flex metal hose kits. It eliminated all the problems.
I'm not sure about soap but a little antifreeze or glycerin will also act as a lube and for sure be safe.
Of course be sure to thoroughly clean the fittings on the water pump and radiator before installing the new hose. These can get rough with corrosion over time.
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Originally Posted by eschoendorff
Will using liquid soap as a lube harm the cooling system? Never heard of that...
You really only use enough liquid soap on the tip of your finger, to lubricate the inside of the hose and the outside of the metal you are sliding over and since it stays there, I doubt if any of it enters the cooling system
seeya
