engine/tranny bolts...
Old Dec 19, 2004 | 04:57 PM
DrEvil11417's Avatar
DrEvil11417
Default engine/tranny bolts...
is there any trick to getting to the bolts that bolt the tranny to the engine before i go digging at it?
car is an 86 auto
Old Dec 19, 2004 | 05:07 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If you can't get to the top bolts with long extensions & swivles you may need to tilt the engine & tranny a bit.
Old Dec 20, 2004 | 06:23 AM
rodj's Avatar
rodj
Ditto above.
Pull the dist and tilt engine back so the top bolts are clear to access
.Make sure the bottom bolts are still in so the trans doesn't fall of the engines dowels.
When I have the top bolts out I level the lot up and support the sump before removing trans.
Old Dec 20, 2004 | 08:58 AM
comp's Avatar
comp
3ft extension
Old Dec 20, 2004 | 09:14 AM
MrRenoman's Avatar
MrRenoman
Ditto to the above, plus I use an impact gun to remove the bolts.
Old Dec 20, 2004 | 11:12 PM
mash557's Avatar
mash557
Also 9/16 swivel socket with above mentioned 3Ft extension. Been there done that, as they said above.
Good Luck
Old Dec 20, 2004 | 11:35 PM
RocketSled's Avatar
RocketSled
Buy two 12" extensions and use the otherone you already have...they're a LOT cheaper than a single 3 footer.
Old Dec 21, 2004 | 02:44 AM
VQT88Vette's Avatar
VQT88Vette
Good Luck
I also tape the 9/16 swivel socket so it doesn't flop down too much
To engine/tranny bolts...
