Crossfire to carb?
Old Dec 20, 2004 | 12:25 AM
84 BRONZEBOMBER's Avatar
84 BRONZEBOMBER
Default Crossfire to carb?
What needs to be changed to make it happen?
Is there a place I could take my 84 to get transformed in the northwest area?
Has anybody done this and what problems occur?
Old Dec 20, 2004 | 01:05 AM
jp2002ls1's Avatar
jp2002ls1
If you do a search on the subject you will find that 100's of people have posted on the subject. The major drawback is hood clearance and loss of MPG, although I doubled the hp so I don't know how much the carb or my engine effected mpg.
Some of the things needed are:
carb
intake
new distributor
fuel pressure regulator
new radiator hose
brackets if you have an automatic trans for tv cable
some more minor items.
I swapped my 85 over to carb with my new engine because the TPI wasn't good for high rpm, 400+ hp. the crossfire should be the same type of swap.
Old Dec 20, 2004 | 11:45 AM
CFI-EFI's Avatar
CFI-EFI
Another item is a means to engage the TCC. You WILL be eliminating the computer. You will lose all the advantages of a computer controlled EFI car, ease of starting, drivability, mileage, etc. The carb is a step backward. Good gains can be made with the Crossfire. Porting the stock intake gave me better than a half second in the 1/4 mile. Besides the carb, there are better EFI alternatives.
RACE ON!!!
Old Dec 20, 2004 | 11:50 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
FYI!
Checkout www.crossfire.webhop.net
Old Dec 20, 2004 | 02:59 PM
bogus's Avatar
bogus
It's more trouble than it's worth.
Update the crossfire, or, spend some money and go aftermarket fuel injection.
You can do the following to a Xfire:
Update the intake
Bore out the TBs
Heads
Cam
Headers
ECU
... and more!
A fellow forum member, and 84 owner has his pushing over 300hp (I don't remember if that's crank or rwhp). But his flat runs.
From what I have been able to figure out, the max output of a Xfire is about 400hp... after that, it can't flow enough air.
To Crossfire to carb?
