help..won't startup..something to do w/ fuel
Old Dec 21, 2004 | 07:41 PM
willz's Avatar
willz
Default help..won't startup..something to do w/ fuel
87 L-98
it began by sputtering...like out of gas.. but had 1/2 tank..
did..that a few times...then wouldnt start..
i changed the fuel pump...didnt help...
then put new injectors...ford 19 lb...from summit racing.. didnt help..
i do know i have fuel pressure..injector clicking..and spark..
the only way it runs..if i spray starting fluid in the plunum..
then..that runs out..back to sq one..
what else can i check ?
any is appreicated..
thx, will
Old Dec 21, 2004 | 07:45 PM
69mako's Avatar
69mako
Check the fuel pressure regulator
Old Dec 21, 2004 | 07:50 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Best to attach a fuel pressure guage at the schrader fitting on the fuel rail
But there are some electronic controls that shut off fuel in the event of
A) low or no oil pressure and,
B) no airflow in MAF for 2 seconds or less
You really need a good shop manual.
I would definitely STOP squirting starter fluid in the plenum! That's for sick diesels! You could IMHO do some serious damage to the engine!
Jack
Old Dec 21, 2004 | 07:52 PM
CFI-EFI's Avatar
CFI-EFI
How did you verify that you have fuel? Clicking injectors are no indication. It sounds like you DON'T have fuel. It runs until the starting fluid is gone, then dies. That sounds like a classic fuel delivery problem, to me.
RACE ON!!!
Old Dec 21, 2004 | 07:59 PM
willz's Avatar
willz
i put a fuel pressure gauge.. to check it..
also i released the valve on the fuel rail.. and got lots of gas..
the injector are clicking away..so i asume they are working..
Old Dec 21, 2004 | 08:03 PM
willz's Avatar
willz
i checked the oil press sensor...and its working..
maf is good...
but even if it was maf is disconnected it should run on limp mode..
Old Dec 21, 2004 | 10:47 PM
jfb's Avatar
jfb
There is a HUGE sign above your vette: NO FUEL !!!!!!!!!!!!!!!!!!!!!!!!!!!
Its nice that your injectors are clicking, its nice that the pressure at the shrader valve is correct, its nice that fuel comes out of the shrader valve when you open it, the only thing that isn't nice is that fuel is not being sprayed out of the injectors into the manifold and that is what you need to find out why! While someone cranks the engine, you should smell the exhaust. It should smell like raw fuel if the injectors are doing their thing.
Old Dec 22, 2004 | 03:02 AM
Joer350's Avatar
Joer350
I had the same thing with mine if you look at the posts about a week ago. The problem with mines was the gas had gone bad. So I changed the fuel pump, injectors and fuel regulator. But it was the gas.
How long was your car sitting or is it a daily driver. I would do the following disconnected the line that sends fuel and put a hose to it and have it empty out to a gallon or container. You will need to have 12volt current to your bottom left connector of the ADLC. I used jumper cables and wire to energize to pump from the battery. ( saves you the head ache of sucking out the gas )
It worked for me and by the way my gas looked like squirt and had no smell to it. Hope fully it works for you
Old Dec 22, 2004 | 03:45 AM
hippy's Avatar
hippy
Did you check your fuses? Inj 1 and 2.
Old Dec 22, 2004 | 03:47 AM
bogus's Avatar
bogus
Willz, I am free tomorrow or Thursday, want me to cruise up?
Old Dec 22, 2004 | 10:03 AM
VAHROOM's Avatar
VAHROOM
This may sound like a silly question but, did you check the filter? I have seen a clogged filter cause just the symptoms you described.
Old Dec 23, 2004 | 10:44 PM
willz's Avatar
willz
i've changed my fuel filter 6 nos ago..
i drive it daily...but did let it sit for a month just recently..
i'm getting gas to the fuel rail//and new injectors..
Old Dec 24, 2004 | 01:17 AM
jfb's Avatar
jfb
If the fuel pressure drops while you are cranking, you have a fuel delivery rate problem. A clogged filter (not matter how short a time ago it was installed), or a pinched fuel line, or a defective pressure regulator may be at fault. Just running the fuel pump without cranking can show normal pressure.
Old Dec 25, 2004 | 07:51 AM
mash557's Avatar
mash557
Didn't really get it from other posts, but have you tried starting it with the MAF disconnected. I had a failed MAF sensor and it did the same thing. I replaced filter, pump, pulled hair out and after unplugging MAF it started right up. It was limp home mode, but it ran. Good Luck
Old Dec 25, 2004 | 11:50 AM
C4Ownr24's Avatar
C4Ownr24
You do realize that the ECM has to recieve reference pulses from the ignition system to even turn on the fuel system....The relay will pressurize the fuel rail, but the injectors won't even fire unless it sees ignition fire - your spark plugs could even still be firing, but without the ECM relaying that message to fuel delivery, you wouldn't have fuel.
To help..won't startup..something to do w/ fuel
