Alternator, ECM, or Dash failure?
Old Dec 22, 2004 | 12:51 AM
Tvnewsengineer's Avatar
Tvnewsengineer
Default Alternator, ECM, or Dash failure?
9 days ago, I the alt. failed on my '86. I had my mechanic put a new one on. Picked up vette on Monday and dash starts freaking out , all lights come and go. You can make out the volt gauge occasionally and watch the volts go down to 11.7 or so. Car starts sputtering and tries to stall. Then out of the blue, dash is normal, volt gauge returns to 13.7, car runs like a champ. I've tried various senarios, driving down bumpy road, cold temp, operating temp, totally random. I've had mechanic double check alternator, check grounds, next is to try to pull codes again (tried Tuesday, but either scanner wouldn't work with OBD 1, or ECM is dead, no reading at all). No check engine light either. Any help or ideas would be appreciated.
Old Dec 22, 2004 | 02:16 AM
bogus's Avatar
bogus
if you can't connect to the ECU, it's doa.
Old Dec 22, 2004 | 10:53 AM
Steel Blue 91's Avatar
Steel Blue 91
This would be my guess as well.
Old Dec 22, 2004 | 12:29 PM
jfb's Avatar
jfb
Remove the battery cables (neg first) and clean both the cable lugs and the battery posts and replace the cables (neg last).
Old Dec 22, 2004 | 04:14 PM
Mike_88Z51's Avatar
Mike_88Z51
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
I agree with jfb, double check the battery cables. My brother's 89 was worked on by a reputable shop and started having similar problems after the job. Being a good shop they disconnected the battery per FSM instructions and when they reconnected the negative battery cable they didn't get it connected right. Turns out a previous repair at a not so good shop had screwed up the cable and if you didn't get it seated just right, the cable wouldn't conduct properly. New cable solved the problem. These cars are actually electrical devices with an auxillary fossil fuel powerplant. Without proper electrical current NOTHING works right.
To Alternator, ECM, or Dash failure?
