How accurate is the G-Tech Pro?
Old Dec 22, 2004 | 06:21 PM
OneRedLT4's Avatar
OneRedLT4
Default How accurate is the G-Tech Pro?
I hesitate to ask this for fear the answer will negate my results. I purchased one a bit ago and just pulled it out of the box and installed it per the instructions. After a couple of HP runs and minimizing the wheel spin, the car's averaging 322 to the rear. With a 15% loss through the drivetrain (an estimate, I know) that equates to 370 at the crank! Can this be? Only mods are Airfoil, Elims, K&N, Power Programmer, cut lid, and TB bypass. Any thoughts? Should I be happy and not look a gift horse in the mouth?
Old Dec 22, 2004 | 06:30 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
sounds pretty optimistic to me. I would expect your mods to land you in the 300-310rwhp range.
Old Dec 22, 2004 | 07:07 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
They claim they are within 2% of accuracy. I agree that it sounds optimistic, but I think it is the airfoil that did it
Just playin'.
Old Dec 22, 2004 | 07:34 PM
redvette6spd's Avatar
redvette6spd
what is a g tech pro
Old Dec 22, 2004 | 07:53 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
A G-Tech is an accelerometer that mounts within the car to give acceleration, 0-60, and 1/4 mile data.
Are you sure that the G-Tech isn't reporting crank HP?? To check, look at your trap speed and use the launch weight of your Vette to calculate crank HP.
Old Dec 22, 2004 | 08:09 PM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
My LT-4 with comparable mods made 305 at the wheels. Just as a point of comparison. I'd say 370 at the crank is a bit optimistic.
What 1/4 mile time did it give you? I've gone 12.90s with mine.
Old Dec 22, 2004 | 09:05 PM
OneRedLT4's Avatar
OneRedLT4
Hehe...that's coming, probably by the end of the week. Also, what weight does everyone put into the G-Tech?
http://www.gtechpro.com/ (sorry one handed-typing with toddler in hand)
Old Dec 22, 2004 | 10:33 PM
BowTieBlood's Avatar
BowTieBlood
Just playin'.
No doubt about it, it's the airfoil. Just think if you would have slapped on some of those 50 hp catback systems!!!!!!
Old Dec 22, 2004 | 10:47 PM
65Z01's Avatar
65Z01
Your launch weight will vary. For example, my launch weight with 1/4 tank of fuel, no spare nor jack and a 170lb driver is about 3,370lbs.
You can use time slip data or get 1/4 mile data from your G-tech. Trap speed on the G-tech will be 1-2mph higher than on time slips due to the way trap speed is measured by the track timers. So you can use G-tech data & launch weight estimate to calc chp.
Old Dec 22, 2004 | 11:48 PM
chriswtx's Avatar
chriswtx
My car weighs 3470 with me(150lb) and 1/2 tank of gas. What was your mph...My experience with the Gtec was it was pretty accurate in the 1/4mile time and mph...
Old Dec 23, 2004 | 12:47 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Gtech measures actual acceleration. So it's output is RWHP minus a little for aero drag (which is why you should do your HP runs in 1st or 2nd)
I have a hard enough time finding a level road to use it on... I think most of the accuracy is lost in not getting it level and the cars tilt when accelerating, which will boost your numbers.
I used it twice at the track, and it was off about a tenth and a half both times.
MPH was way high though. I've even gotten a 107 mph 1/4 mile run out of it with my stock L98, which is total b.s.
As for the trap speed vs 1/4 mile instantaneous speed, Gtech says thats why their mph reads 5 mph high, but its b.s., those values don't vary by more than 1 or 2 mph in reality, unless you're powered by thrust from a jet engine.
Old Dec 23, 2004 | 04:37 AM
conv90's Avatar
conv90
G-Tech should be used to compare performance when you do some modification.
I never used for HP calculation.
I found that it is very VERY accurate on the same road, and that you can obtain the same results (in the same road with the same weather contition..)
So if you bump the fuel prssure (just for test) and you perform a run (0-60) and you obtain a better time, you can be SURE that your mod is fine.
I don't care if the time of 5.39 sec is right, but I'm happy to see that with a mod i can lower this time to 5.20 sec and see that if I return to the original setting the time return to 5.40 range.
-Beppe-
Old Dec 23, 2004 | 04:43 AM
BIG JIM 54's Avatar
BIG JIM 54
You need the G-Tech Competition Pro...
A good price for it is about $275.00. You can't get anything accurate for $49.95. The GTCP has 3 accelerometers and is accurate to 1% and repeatable within 5%. So says the instructions anyway.
I haven't hooked mine up yet pending some other mods. I will report when it's functional.
BIG JIM
Old Dec 23, 2004 | 06:59 AM
OneRedLT4's Avatar
OneRedLT4
Per the instructions, I put in that big weight number off the door sill. I'm guessing that it's not really much of a pig. Hmmm, I think I'll go out and buy 3 more bathroom scales, lay them out, and drive all four tires up on them, and add the numbers to get a realistic weight . Don't know where else I can weigh the car.
Old Dec 23, 2004 | 08:11 AM
runner140*'s Avatar
runner140*
Default I've got one (G Tech).....
I don't know about the HP test but the 0-60 and 1/4 mile and 60-0 runs are quite accurate. Had it for about two months and use it for testing new parts, ie. brakes--pads and rotors and new tune-up--plugs wires etc.
To How accurate is the G-Tech Pro?
