Erratic idle when first started
Thanks in advance.
Sorry I can't help, but here's a bump and I am sure someone will be along in a minute with the answer
Merry Christmas and Happy New Year
Jack
Jack
Yeah, I was amazed that it would run too. Tonight, got in it at work, no problems at all, was idling just fine just after startup. Had to stop on the way home, idling just fine after startup again. I am at a loss.
Great site with helpful pics.
Merry Christmas and Happy New Year!
The computer ECM has several modes: Start, Clear Flood, Run, Acceleration, Deceleration, Batt-Volt Correction, and Fuel Cutoff.
Start Mode
When the ignition switch is turned to the On position before engaging starter, the ECM energizes the fuel pump relay for two seconds to allow the fuel to pressurize. The ECM then checks the Engine Coolant Temperature ECT, Throttle Position TP and Manifold Absolute Pressure MAP to determine the proper air/fuel ratio for starting. This ranges from 1.5:1 at -36 C (-33F) to 14.7:1 at 94 C (201 F) running temperature. The ECM controls the amount of fuel delivered in the starting mdode by changing how long the iinjectors are energized. this done by pulsing the injectors for very short times.
RUN mode
The run mode has two conditions called Open Loop and Closed Loop.
When the engine is first started, the engine spped is above 400 rpm the system goes into Open Loop operation. THe ECM ignores the signal from the O2 sensor and calculates the air/fuel ratio based on inputs from the ECT and MAP.
The system stays in Open Loop until the following are met:
1 The oxygen sensors O2 have varying voltage output showing that they are hot enough to operate properly.
2 The ECT sensor is above a spec ified temperature about 40C or 104F.
3 A specific amount of time has elapsed after starting the engine.
Specific values for the above conditions exist for each different engine, and are stored in the Programmable Read Only Memory (PROM). When these values are reached, the system goes into Closed Loop operation.
In Closed Loop operation the ECM calculatese teh air/fuel ratio (injector on time) based primarily on the signal from the O2s. This allows the air/fuel ratio to stay very close to 14.7:1.
I think first you should check your vacuum for leaks. Then check ECM grounds for clean, tight and proper ground.
Next:
Look at cleaning the throttle body.
Injector balance.
Fuel pressure issues.
EVAP control systems.
O2 sensors checks.
Additionals:
MAP sensor
Throttle linkage for sticking or binding
then IAC
I don't recall if you said if it hard started, or just fired right up and then idled badly. This assumes your talking about a cold engine.
Start Mode
RUN mode
Next:
Injector balance.
O2 sensors checks.
Additionals:
MAP sensor
then IAC
It always fires right up but occasionally idles very slowly. For instance, no problems at all today, the idle was where it is supposed to be. When this extremely slow idle condition happens, it's with a cold engine and it seems to clear itself up after reaching operating temperatures. BTW, I checked the throttle body tonight and it's really dirty on the backside of the butterflies, so it looks like I have that to take care of after checking the vacuum and ECM grounds.
Thank you for the information.
I'll let you know how it goes. Thanks again.... Merry Christmas and Happy New Years to you and your family.
