new chip for 383 or run it
Old Dec 22, 2004 | 07:04 PM
rugby!'s Avatar
rugby!
Default new chip for 383 or run it
ok one last check to make sure i have everything
91 auto
1. zz383 crate motor from gm (425chp/460ctq) ordered
2. 2400 stall have
3. trans cooler have
4. tpis coated headers and front y-pipe ordered
5. water pump have
6. superram intake have
7. walbro 255lhp fuel pump ordered
8. 24# bosch injectors ordered
if there is anything else please let me know i dont want to have to order something after the work has started.
the trans will have to be stock until i blow it up.
i know i will need a new chip burnt. i am having the motor installed one place and having the car dynod and the chip done about 20 miles away will the car run at all after the new motor put in or do i have to trailer it the the dyno shop.........thanks for the help and pray for the best
Old Dec 22, 2004 | 07:28 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
if that is a 91 you are dealing with you will definatly need a chip just to get it running probley
Old Dec 22, 2004 | 09:44 PM
Hole-Shot's Avatar
Hole-Shot
absolutly on the chip
Old Dec 22, 2004 | 10:35 PM
FD2BLK's Avatar
FD2BLK
You need a chip, I wouldn't even start my motor untill I had a baseline mail order bin (or chip in your case) If you end up way lean it can cause dammage and if you end up too rich you could wash the rings out. If I where you and had just droped all that $$$ in the motor I would spens a little more and get a base line chip then get TTS data master and a cable if posible and logg data as soon as you start it up.
Old Dec 23, 2004 | 12:49 AM
Steve85's Avatar
Steve85
Cruise-In V Veteran
Go to the dyno guys, have them prepare the baseline chip for the drive over.
To new chip for 383 or run it
