New LT1 to LT4 conversion package
Old Dec 23, 2004 | 04:45 PM
94brick's Avatar
94brick
Default New LT1 to LT4 conversion package
Take a look at this package. LT1 to LT4 conversion with CNC aluminium heads. For those that know, is this a good deal?
http://www.sdpc2000.com/catalog/3473...m-and-CNC-Head
Old Dec 23, 2004 | 04:58 PM
STL94LT1's Avatar
STL94LT1
Yeah, that is a pretty good deal.
Old Dec 23, 2004 | 05:07 PM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
That looks like a good price but I wonder what the heads flow and if they've done a 3 angle valve job. I also wonder if the intake has been ported?
Old Dec 23, 2004 | 05:10 PM
bobmic93's Avatar
bobmic93
So 3 grand for parts ,probably 2 grand labor. What kind of increases in hp & tq will you see with this? Whats a stock lt-4 have ? 330 to 350hp. I think thats a lot of doe for 50hp upgrade. It might be a good deal, I just expect more for my 5 Gs.
Old Dec 23, 2004 | 05:13 PM
STL94LT1's Avatar
STL94LT1
With the proper tuning in a M6 car you'll be around 360 rwhp, depends on you other mods.
Old Dec 23, 2004 | 05:17 PM
Zix's Avatar
Zix
This package will net more power than a stock LT4 because they are CNC ported LT4 heads, and the LT4 Hot Cam is a nice bump up from the standard LT4 cam. With the stock exhaust manifolds in place you'll probably see around 340RWHP, get a set of longtubes and you'll be good for the 355-365RWHP area. I would say it's a pretty good price and it doesn't look like there is a core charge at all so you could sell your original LT1 heads and intake and get a little bit of cash back.
Old Dec 23, 2004 | 05:33 PM
bobmic93's Avatar
bobmic93
Ok, I thought the Lt-4 vette has the hot cam in it. So with proper tunning and headers your talking close to 100 hp. See! Thats what Im talking about. That should put you up their with the 400 cHp club. I like it.
Old Dec 23, 2004 | 06:04 PM
tvetta's Avatar
tvetta
Guys,
You can buy the Hot Cam Kit for $489 from SamTaylor and get the heads done from Bob at Precision Porting for $1400, buy some Impalla SS head gaskets for $25, LT4 intake for $220 and they you save $900.
That is the direction I would go.
Old Dec 23, 2004 | 06:16 PM
STL94LT1's Avatar
STL94LT1
tvetta, this package includes the heads, no core charge.
Zix's Avatar
Zix
Originally Posted by tvetta
Guys,
You can buy the Hot Cam Kit for $489 from SamTaylor and get the heads done from Bob at Performance Porting for $1400, buy some Impalla SS head gaskets for $25, LT4 intake for $220 and they you save $900.
True, but for the little extra cash you get the LT4 heads which are a little better than the LT1 heads. Also, if he sells his current LT1 heads and intake for 400-450$ then the price difference in negligable. And that $400-500 extra would be worth it for me if I didn't have to wait while I sent my heads out for porting...that's just a lot of extra time the car is down. With this package it's just a clean swap.
Old Dec 23, 2004 | 06:22 PM
VenkmanP's Avatar
VenkmanP
I got the LT4 heads and intake new for about $1100.
Getting them ported, plus rockers, custom cam, gaskets should cost me less than $1500. And then I've got a custom cam vs. the hot cam and possibly better porting.
Looking at it another way, I think you can get the basic LT4 conversion kit (unported) for about $2k, then you could get them ported and a custom cam for less than $1k.
So no it doesn't look like anything special. Perhaps more convenient than the other options.
There's also a lack of detail in the desription. For instance what springs are they using?
Old Dec 23, 2004 | 07:36 PM
Zix's Avatar
Zix
You're going to get them ported, plus rockers and a custom cam for under $1500? That's pretty cheap, who's doing the work? What kind of flow numbers are you expecting? Either way that's a good price!
I had my LT4 heads ported a while ago, and it cost quite a bit more than that...granted they are set up for a big-inch motor that being installed next month...but the port work alone cost me $1250 (stage 4 flows well over 300CFM) and that's not including any parts (valves, guides, etc). I could have got them a little cheaper for the 350 bottom end, but I didn't want to have to do them again.
Anyway, like I said, from my point of view this is a decently priced package, and it comes with just about everything...except I'd probably add in some ARP bolts.
EDIT: as for the springs...I would assume the ones that come with the Hot Cam kit as that is what they are including I beleive
Old Dec 24, 2004 | 12:06 AM
cprgmr's Avatar
cprgmr
"our own CNC ported LT4 cylinder heads"
This kind of scares me. Since when did Scoggin Dickey enter the CNC head porting business? Aren't they a dealership?
Old Dec 24, 2004 | 12:23 AM
Zix's Avatar
Zix
They make their own crate engines, and very nice ones too...I see no reason why they can't port heads. I would like to see flow sheets however.
Old Dec 24, 2004 | 12:29 AM
cprgmr's Avatar
cprgmr
Making crate engines and investing in multi-million dollar CNC machines are a little different. I agree though - if they can produce good flow numbers, I'll give them the benefit of the doubt!
Old Dec 24, 2004 | 12:45 AM
Zix's Avatar
Zix
It's also possible they send them out, like TPIS does with their AFR heads. AFR does the CNC work based on the specs given to them from TPIS.
Old Dec 24, 2004 | 12:49 AM
JCAIRE2's Avatar
JCAIRE2
Scoggin-Dickey has a fully equipped machine shop that does all of their work, from CNC to assembling custom crate engines. I worked there last year Heads are probably done on the rottler CNC.
To New LT1 to LT4 conversion package
Old Dec 24, 2004 | 12:58 AM
Zix's Avatar
Zix
Good deal! Now hook us up with some flow sheets!!
Old Dec 24, 2004 | 01:29 AM
VenkmanP's Avatar
VenkmanP
I have no solid plans but probably will use Lloyd Elliot. Not looking for anything major just a mild porting and match the intake.
His stage 1 porting is $750. He's getting 255/180 from LT1 heads with this package. Custom cam is another $350.
I could go to somebody local and get it done for less than that, but I'd prefer to go with somebody with proven results with LTx heads.
Old Dec 24, 2004 | 02:21 AM
BAM92's Avatar
BAM92
Better yet, get your job back and meet me by the back door.
