Handling
Old Dec 24, 2004 | 01:03 AM
Luna's Avatar
Luna
Navigator
Default Handling
A Vette Newby here. I need some input from some old hats.
My 91 really dances, pulls and darts when I drive over uneven pavement. It's really bad where big trucks have made ruts and road snakes in the asphalt. Is this something I've got to live with or could I have shock or tire problems?
Old Dec 24, 2004 | 02:19 AM
McShagger's Avatar
McShagger
Can you give us some more info? Like what you think the problem might be? Tires, wheels, steering, suspension, shocks, alignment... It could be any of those things. Where are you from? If theres a knowledgable member close by, Im sure they would mind taking a look at it for you.
Old Dec 24, 2004 | 04:32 AM
Wayne88's Avatar
Wayne88
Some of those truck ruts are so bad, no car will handle evenly.
But I think that C4's "sideslip" [I think thats the word], when making fast curves over bumpy road. I know mine does.
Old Dec 24, 2004 | 05:54 AM
KEVS_L98's Avatar
KEVS_L98
i have had this same problem and i think there is a post on here somewhere about coil over suspensions and it touches on the sidestep
I know my '89 coupe does it here in Dallas home of the biggest pot holes in America.
Kevin
Old Dec 24, 2004 | 06:01 AM
Ten9T6-LT4's Avatar
Ten9T6-LT4
Kevin
yeah..some of the pot holes near my house could take a Vette completely out...
My car does pull on some of these roads...I noticed it more when I put wider tires on the front....
Old Dec 24, 2004 | 06:08 AM
Steel Blue 91's Avatar
Steel Blue 91
As Ken stated, alot of it has to do with wheels,tires and suspension. The General tried to address this "issue" in later models (92-96) by softening the FE1 Soft ride suspension an using a 17 x 8.5 rim in the front (vs the 17 x 9.5 rim on all corners). My 91 does the same thing. It's the nature of the beast.
Old Dec 24, 2004 | 07:54 AM
rws.1's Avatar
rws.1
How is your front end aligned?
My '88 "tramlined" alot ( followed the ruts) . Following up on a number of posts, I had the front end aligned to Advanced Street settings and the problem was almost completely eliminated.
I got the settings from the web site http://www.vbandp.com/instruct/align.htm
Good luck
Old Dec 24, 2004 | 07:57 AM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
what is your front tire size?
My car is aligned and it still does what yours does. But I know that it's from the 275's I have up front. It didn't do that when I had the 255's up there.
Old Dec 24, 2004 | 08:53 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Beside checking the car's alignment, you may need new shocks.
Beyond that, wide tires & stiff suspensions contribute to the 'nervousness' of a Corvette. You'll never eliminate it completely.
Larry
Old Dec 24, 2004 | 10:39 AM
mikey whipreck's Avatar
mikey whipreck
Those wide tires are gonna find the groves in the rode...
Try finding a newer/smoother rode... do you experience the same problems?
Old Dec 24, 2004 | 03:49 PM
lbitp37's Avatar
lbitp37
Dont worry about it . The wide cause the car to track in those grooves.
Old Dec 24, 2004 | 05:01 PM
Luna's Avatar
Luna
Navigator
Continuation to my earlier post.
I live in the Montgomery AL area. She has Sumitomo (315/35ZR17 Rear - 275/40ZR17 Front) tires and Bilstein shocks. The suspension/steering is tight. An alignment is on the agenda, "IF" I can find someone who knows what he's doing. A few years ago (18 acually) I was an ASE certified technician working for Porsce,Audi, VW dealerships. So...when I ask a Chevy dealer if they can align my Vette and I get an answer like.."Do you align the rear end on those?"....I tend to shy away. From all the replies I've determined that my concern is basically the "nature of the beast". But I'm going to change shocks and get her aligned anyway. Thanks ya'll for all the input.
Old Dec 24, 2004 | 05:05 PM
fsr402's Avatar
fsr402
St. Jude Donor '06
yup the 275's will do that. If you were to put on the 245's that the C5's run you would not have this problem anymore.
I like my 275's to much to do that, so I'll just hold onto the wheel a little better.
Old Dec 24, 2004 | 05:09 PM
Frizlefrak's Avatar
Frizlefrak
. So...when I ask a Chevy dealer if they can align my Vette and I get an answer like.."Do you align the rear end on those?"....I tend to shy away. .
Smart of you to shy away. There is nothing mysterious about the C4 suspension, and any competent alignment tech can do it for between $75 and $100.
It does seem to be the nature of the beast, but you can reduce it. Explain the crowning problem to your alignment tech, and he may be able to recommend some different toe settings to address the issue. Also play with your tire pressures and see if changing them helps reduce it.
Good luck.
Old Dec 24, 2004 | 06:25 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Just before I had new rubber installed on my '88 I was beginning to notice some wandering on grooved highways.
After the new 275/40 Eagles went on around, along with a stock spec. 4-wheel alignment, tracking is dead on.
Check tread depth and replace if it's time, check inflation and 4-wheel alignment.
Old Dec 25, 2004 | 05:03 PM
Daffy's Avatar
Daffy
Florida turtle advocate
St. Jude Donor '05-'06
I have one with 285s on 9.5s in the front.....Follows everything in the road....Loves the curves though so it's worth it..
To Handling
