Q For rear coilover users
Old Dec 24, 2004 | 02:03 PM
JayH's Avatar
JayH
Default Q For rear coilover users
How often do you guys inspect the rear knuckle and that lower mount point? How many miles you got on those coilovers?
I keep hesitating to go coilover in the rear because of that single shear lower mount.
Thanks,
Jay
Old Dec 24, 2004 | 03:33 PM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
I look at mine almost once a week. Since I got my 4 post lift.
I've put about 5K miles on them
Old Dec 24, 2004 | 05:43 PM
tkrussell's Avatar
tkrussell
I was concerned about that also, so I looked into it.
The suspension gurus say that instantaneous peak stress loads on the shock mounts are higher from the shocks than any spring loads would ever be. If the shock mounting points are durable before coil-overs, they will be OK afterwards.
Some installation tips for max durability:
1) Inspect, preferably with dye penetrant, the rear control knuckle for micro-cracks.
2) Use new lower shock bolts, and preferably cryo-treat them.
I inspect the suspension every 6 months, spring and fall, along with other routine preventative maintenance. That has been plenty.
Old Dec 25, 2004 | 01:58 PM
JayH's Avatar
JayH
thanks for the input. i think its finally time to do the rear
Jay
To Q For rear coilover users
