Thumper Turbo Part II
Old Jan 12, 2005 | 01:12 PM
Baldturbofreak's Avatar
Baldturbofreak
hmm, now that I have calculated the total approximate weight of the chiller assembly(full of coolant), I might put it where the turbo is, and mount the turbo to the actual rear end. It would also open up the possibilty of bruce having a rear exiting exhaust as well.
Old Jan 12, 2005 | 02:57 PM
mn_vette's Avatar
mn_vette
why couldn't you mount the coolant tank to the rear end? Is the weight between the tank and the turbo that much. How big of a tank are you running? It would be a shame to redo all that welding when you're so close to getting the thing started.
Old Jan 12, 2005 | 08:59 PM
Baldturbofreak
actually, it would only take a half hour. Metal is putty in my hands. Yo, we just got a 75 ton press at the shop. It's sooooo fun to crush the shiit out of stuff. The tank and coolant will weigh about 10 lbs more than the turbo, and it will make it easier to do the exhaust pipe and intake. It's more to do with the shape of the tank and where things have to fit for the oil system.
Old Jan 13, 2005 | 12:49 PM
spindoctor's Avatar
spindoctor
I like this! Great idea.
What size is the turbo?
Is the Ypipe 3.5"?
Old Jan 13, 2005 | 01:13 PM
Baldturbofreak
Is the Ypipe 3.5"?
nope she's 3 inch to keep velocity high. the turbo is a Tv-85 from a detroit diesel. It has a 85mm inducer bore with a 125ish mm major dia. it will pump 130lb/min or 1300hp worth of air. As for your next question about lag with a thumper, boost threshold is determined by turbine a/r (in this case 1.39) so if it doesn't have the response we want, There is a multitude of much tighter .87 to amuch much looser 3.2 a/r. (I wonder what the hell type of application needs a 3.2 a/r?) I have a 1.23 on my 81mm thumper and I get boost by 3400, full by 4000.
Old Jan 17, 2005 | 10:06 AM
Baldturbofreak
well it' all moved. Hung right behind the rear end. It's gonna look cool with a 5" chrome tailpipe from a kenworth! I found the perfect Rci plastic tank to go where the storage compartment was. And it make it easier to run the a/c line back to the secondary evaporator. Just gotta cut the top out of the tank to get it (the evaporator) in there. I just hope the throttle doesn't ice up from the freezing boost temps! I have some new pics if someone can host them.
Old Jan 17, 2005 | 01:19 PM
mn_vette's Avatar
mn_vette
Shoot them to me in an email and I should be able to post them for you. mckevett@us.ibm.com
Just for the fun of it you should post the pics on the Camaroz28.com forced induction board with the title "STS This!" it would get alot of attention with all the sts debates going on over there right now. It would be amusing to see the replies
I'm not so sure I like the idea of a single tail pipe on a vette though, just doesn't seem right.
Old Jan 18, 2005 | 10:34 AM
mn_vette's Avatar
mn_vette
Here's the pics that Rick sent me:
It looks like you lost a couple of inches of ground clearance with that setup. Just be careful going over speed bumps!
Old Jan 18, 2005 | 03:20 PM
Baldturbofreak
The pipes aren't on the hanger's yet so thats whey to cold side is hangin low, other than that it doesn't hang down any farther (actually it's above) the x brace under tha car. Just don't back into any curbs.
Old Jan 18, 2005 | 05:34 PM
lcvette's Avatar
lcvette
pics not workin man ya damn turbo teasin bastards!
lol
Old Jan 18, 2005 | 06:34 PM
mn_vette's Avatar
mn_vette
apparently I've exceded my bandwidth quota. It says it will work again in 12 hours. Sorry.
Old Jan 20, 2005 | 06:51 PM
Baldturbofreak
Bruce. are you going to be home on saturday? I start school on monday so I will have less time (not that one day a week takes up any) and I would like to pull double duty this weekend. I simply MUST hear this thing whistle soon or I will go crazy. here's whats left
Oil tank, oil pump, oil cooler, wiring
Fuel system routing
Big big air filter.
tailpipe.
Rollbar.
Boost controller.
reinstall all of the radiator & components (after were certain your opti isn't farked)
plug wires
Iat in intake pipe
Paint intake pipe.
Coolant tank, pump,hoses, wiring, a/c lines
Dyno tuning.
Old Jan 20, 2005 | 11:43 PM
BAM92's Avatar
BAM92
Are you guys just going have one tailpipe exiting on one side? Or are you going out the center? Pics haven't come up yet so I have to ask. If you go out one side are you going to make a dummy one for the other side? It is gonna be wild to here a turbo boost from behind you.
Old Jan 22, 2005 | 01:36 PM
Baldturbofreak
well no work for us this weekend. DAMN BLIZZARD!
Old Jan 22, 2005 | 03:41 PM
TONYDEE64's Avatar
TONYDEE64
Bruce, you're going to drag turbo on the ground when you start doing wheelies. My hat's off to you gents.. I dig the originality! Rick, what's going on with your car?
Old Jan 22, 2005 | 03:57 PM
Baldturbofreak
Well it's mainly money right now. My motor is awaiting cryo, I need a small base cirle cam (gonna do the 4&7 swap,too) and after that I need a buch of nickel and dime parts.
Need some more side work!
To Thumper Turbo Part II
