Mixing tires
Old Dec 26, 2004 | 06:04 AM
LTs LT1's Avatar
LTs LT1
Default Mixing tires
First, I hope everyone had a wonderful Christmas..
I need to replace my two rear tires. I currently have Firestone Firehawk SZ50's all the way around, but my front tires as nearly new. As you may all know, Firestone no longer offers the Firehawk SZ50's (at least in the size I need 285's). I will be purchasing Kumho ECSTA Supra 712's, but was wondering if I could get away with just replace the two rears I need? (the two front tires are like new)
Will this cause a problem? The Kumho 712's are recommended for replacing the Firehawks, but I was wondering if mixing the two would be problematic? Any advise would be appriciated...
Old Dec 26, 2004 | 08:21 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
No worries whatsoever!
Old Dec 26, 2004 | 10:11 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
I don't see a problem, but you may want to post this question over in Wheels & Tires and let the experts chime in.
Larry
Old Dec 26, 2004 | 10:16 AM
ALLT4's Avatar
ALLT4
Whoa, I must be living under a rock. I didn't know the SZ50's were no longer available. I have these all the way around right now and they are going to need replaced in the spring. Are those Khumo's or whatever the best replacement for those? I'm after more treadlife than performance. I'll probably have drag slicks also for occasional strip use.
Old Dec 26, 2004 | 10:36 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I have Duncrap SP8000's on the front and the superior Michelin Pilot Sports on the rear, no problems at all, you don't want to mix side to side. As long as each axle has a match, you are fine.
Old Dec 26, 2004 | 10:44 AM
1stC3Vette's Avatar
1stC3Vette
There should be no problem mixing tires as long as you stay axle to axle. Did you try the SZ50 tire in a 275 or 295?
Good luck.
Dino
Old Dec 26, 2004 | 11:58 AM
Corvette Kid
Oh and BTW, I'm running Kumho MXs on the front now (I killed the rear ones ) and Nitto DRs on the rear and will be staying with that set-up. It still handles very well, even running the Nittos at 26 psi for street use.
Old Dec 31, 2004 | 02:44 AM
LTs LT1's Avatar
LTs LT1
Default Thanks
Sorry for the late reply, I have had some problems with my computer
Thanks to all that responded. I am glad to hear I will be able to save $300.00 and only buy two rear tires...
Oh and by the way, My brother just sold his z06 and bought a 2005 C6 (Corvette Yellow). It is a very nice car!!!! He had planned to wait until the 2006 Z06 came out, but then he heard they will be starting at $75K... I hope they don't due what they did with the ZR-1 and price them out of most people's range...
Well thanks again and Happy New Year to all!
Old Dec 31, 2004 | 08:19 AM
runner140*'s Avatar
runner140*
Default No problem.....
They are a perfect match.
Old Dec 31, 2004 | 08:23 AM
Brimis's Avatar
Brimis
I have Yokohama's on the front and Kumho Ecsta Supra 712's on the rear of my 84 and the car rides fine.
Old Dec 31, 2004 | 09:41 AM
the blur's Avatar
the blur
the SZ50's are garbage anyway. anything less than 35 degree's outside, they are completly worthless. THey turn hard as rocks, and give 2% traction.
Old Dec 31, 2004 | 12:05 PM
smack123's Avatar
smack123
I've got Kumho Ecsta Supra 712's all around on my 91 - they are a nice tire, I'm quite happy with them.
To Mixing tires
