Massive smoke billowing from the engine!
If this is the case, which gaskets do I need to buy to complete the job? The intake manifold has to come off, so that is one. There is also the exhaust manifolds, correct? And lastly, the head gaskets. Are there any that I am missing?
Sounds like you have a major leak, and its most likely not a head gasket if its pouring out that much. Just incase, check your oil to make sure it looks ok before doing the above.
Be careful, water on the exhaust causes HOT steam.
Good luck and hope its not the head gasket and just a loose fitting that will take a minimal amount of time to fix. Play with the hoses, it might promote more leakage and make it easier to see the root cause.
Second is I would try to locate the source of the leak.
It could be intake to block/heads or it could be a head gasket.
I would run a LEAK down test on the motor, each cylinder, it should quickly tell you if its a head gasket, among other things.
Next and you an do this one first also, is a leak down on the coolant system. This will possibly tell you were its leaking from.
Then start pulling it apart. I would seek a VERY VERY good flushing agent to rid the lower end of the coolant. It kills bearing very quickly, and you will get to do it all over again if a bearing goes.
If the motor has a bunch of miles on it, I would just opt to have it totally refreshed with new bearing and a good magnifux to make sure the problem wasn't in the block and start over with new rings etc.
A you are definately at a cross roads - might actually be cheaper to just pick up a new shortblock - or its an opportunity to go BIGGER and BADDER.
Good luck and sorry for the troubles.
