Windows Rattling around..
Old Dec 26, 2004 | 05:07 PM
DrEvil11417's Avatar
DrEvil11417
Default Windows Rattling around..
Im sure most of us have faced this problem...
My windows - drivers side in particular - rattle around when im driving. It goes in and out to the side about 1/2".
Im guessing something is worn out somewhere, has anyone tried to fix this problem?
Just wondering what I should be looking for or if they make a kit to fix the problem
Old Dec 26, 2004 | 05:32 PM
JCAIRE2's Avatar
JCAIRE2
Old Dec 26, 2004 | 05:48 PM
cash's90's Avatar
cash's90
Are your outer door/window seals shot? If so, you can buy replacements through Ecklers, Mid-America, etc.
Old Dec 26, 2004 | 07:18 PM
DrEvil11417
yeah the seals are fine, the window just moves on its own. my camaro had the same problem but i sold it before i got a chance to fix it
Old Dec 26, 2004 | 08:29 PM
eptaylor's Avatar
eptaylor
Default Window rattles
There is a felt covered block that pushes up against the window and is adjustable. Lower the window all the way and look down in there. I think it is about 1/3 of the way from the front of the window. If this is loose it could be the problem.
Old Dec 26, 2004 | 09:19 PM
sraft's Avatar
sraft
There also a front window guide (attached to the front lower edge of the window) that (on latter C4s) is made of plastic and eventually breaks. After I replaced the felt covered guides and this front guide my rattles all went away.
To Windows Rattling around..
