Be careful disconnecting the plugs for the defogger, other than that, it's pretty easy. I did it on a C5 and this past Saturday we had to take them off my buddy's '88 to put the new weatherstrip on. They got some funky "C" clips that you have to pry off then the slip right off. We didn't try putting the clips back on, so I can't help you there.
Napa Auto had replacements & they are easy to replace. Only had to move the rubber rings that dampen the targa when in storage from the old to the new. Use a small bladed screwdriver to pop the clips (not all the way off, just enough to release the ball). Had the wife hold the glass while doing it. Easy easy job but now its hard to close the glass the new ones are so strong!!!
Using the "wife holding it" method greatly simplifies the job. If you try it alone, plan on getting crowned on the head a couple of times.
Mine are also strong enough now that closing the glass requires some good pressure to get it to close. Beats the hell out of it careening down on your head though.
I don't have his email here (I'm sure someone will come in with it) but it's Chris May, at Superior Chevrolet. He gives forum members GREAT discounts. I've ordered a lot from him, and have loved the service.
Or if you are single just use vise grips. FWIW I got my pair over the summer for $36 new on ebay and they work great. Took about 10 minutes tops to replace.
On a scale of 1 to 10 with 10 being very difficult, this job is a 1.5...if you have someone hold the rear glass for you! Once you determine where to place the small screwdriver into the holding clips, the struts will come off very easy! Mojo was "right on" with the defroster connections. Take your time and they will come off.
SAM
I don't see any clips on mine to release. Does the 85 have these clips or is it just the newer C4? I know my 88 Camaro had clips when I replaced the hood supports, but this strut is a different design. Any comments appreciated!
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Originally Posted by SwampRat
Really; any comments at all. Don't be shy.....
A - this thread is ancient
B - start a new thread with a picture of how your strut is connected to the ball. Sometimes its really hard to see the clip.
