G92 Perf Axle?
Dec 28, 2004 | 12:12 AM
G92 Perf Axle?
Looking to purchase a C4 and have seen the G92 option. What ratio is this? Thanks in advance!
Don
Dec 28, 2004 | 12:20 AM
2021 C6 of the Year Winner - Unmodified
There should be another RPO code that lists which ratio is installed mine shows G44 3.07.
Dec 28, 2004 | 12:32 AM
Mine is listed as G44 G92
In my case, like teebee, the "G44" denotes the gear ratio. The "G92" means I have a performance axle ratio.
-Eric
Dec 28, 2004 | 12:46 AM
From: Why are there squished peanut butter cups in my underware?
It depends on the year and coupe or vert for some years.
This applies for automatics only.
Dec 28, 2004 | 02:32 PM
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
-Eric
The G92 only means the performance axle ration option... it should be a 3.07 though.
Dec 28, 2004 | 02:57 PM
Everyone is close on this...
The problem is understanding how GM issues RPO codes. Some only trigger other codes. Makes sense?
For example, the G92 means you have an optional rear gear ratio. That is all it means.
There are then specific codes to indicate the actual ratio.
You see, what is optional on one care, could be standard on another. So the G92 was used to let the system know it was getting a non-standard ratio.
I don't know all the ratio codes... the damned forum software lost my RPO thread...
Dec 28, 2004 | 04:58 PM
Quote:
http://forums.corvetteforum.com/show...ld+Sheet+Codes
took me 1 search, and about 5 seconds to type the info in...
Why dont you guys like the forum's search?
Dec 28, 2004 | 06:34 PM
Quote:
Originally Posted by mikey whipreck
Cause when Mr Mojo and I went looking for it 2 days ago, it was GONE! I kid you not... it was not to be found ANYWHERE.
Thanks for finding it!
Dec 28, 2004 | 06:58 PM
oh I see... yeah, that would make me dislike the search
Dec 28, 2004 | 07:01 PM
I swear, the servers are in Bermuda...
Dec 28, 2004 | 07:39 PM
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
That is the 3.07 in automatic cars. Doesn't sound that great but with the low gear ratio in the 700R/4L60E transmissions, it launches pretty well.
