Heater Control Valve Location
Old Dec 28, 2004 | 09:54 AM
BIGJIM13's Avatar
BIGJIM13
Default Heater Control Valve Location
HI
does anyone know where the heater control valve is located - it is not listed in my book.
Also what is the thing that is down in the blower housing - it sits on the top of thehousing and hase two electrical connections - when you take it out it has a rounf black module on an metal plate with vanes, what does it do?
Old Dec 28, 2004 | 10:18 AM
c4cruiser's Avatar
c4cruiser
Your profile says you have a 93 and I think that heater temp control is done by a door in front of the heater core and not by a valve as the earlier C4's used.
The module in the housing may be the heater motor resistors. They control blower speed and use airflow to keep them cool.
You didn't say which A/C system you have; standard C60 or the electronic C68 system??
Old Dec 28, 2004 | 01:07 PM
SunCr's Avatar
SunCr
As posted, the '93 doesn't have a valve controlling coolant flow to the core - coolant is always present at the core as it bypasses the thermostat.
The item you described is the blower control module which is used with electronic air. It's an amplifier that gets low voltage signals from the Programmer and increases them for blower operation. It also provides a ground for the compressor when a/c is commanded.
A/c/heat temp is controlled by a door that block/allows airflow across the Evaporator and Heater Core. The door is contolled by an electric motor.
Old Dec 28, 2004 | 01:14 PM
BIGJIM13's Avatar
BIGJIM13
Default Heater no Heat
Many thanks for the replies
so if I am not getting any inside heat then its a thermostate or a door that is not working..is that the general impression?
Would running the codes tell me if there is a problem?
Old Dec 28, 2004 | 01:44 PM
Lichen's Avatar
Lichen
I just had the heater repaired in my '93 and it WAS a faulty heater control valve! Maybe it's one of those things that they changed in mid-93.
Old Dec 28, 2004 | 02:21 PM
c4cruiser's Avatar
c4cruiser
My 92 service manual does not show a heater control valve in any of the schematics, only a temp door in front of the core. My 87 does have an in-line valve on one of the hoses that is operated by a vacuum signal from the heater control lever.
There is a sort of control valve that operates the temp door and that may have been what was repaired in Lichen's case. It's a small vacuum motor and is a common problem when there is no heat or all heat.
If you have the electronic HVAC system, are any of the indicator lights flashing?? They have their own set of codes and can be shown on the Climate Control display. There is a specific code for Temp Door Circuit Fault.
Push and hold the fan up and down arrows at the same time until the display reads 00. This is the diagnostic mode and you can select any of the parameters by using the up and down arrows. To see the value for that parameter, just hit the fan "Auto" button.
If the tem door motor is bad, Parameter 0 will show an 01 or 02 fault.
Old Dec 28, 2004 | 02:26 PM
Lichen's Avatar
Lichen
You may be correct. My extended warranty covered it so I didn't worry about the problem as long as they fixed it and they did.
To Heater Control Valve Location
