94 corvette viberating at ide when in drive
Old Dec 28, 2004 | 01:43 PM
babar sultan's Avatar
babar sultan
Cruising
Default 94 corvette viberating at ide when in drive
i just changed the plugs , wires , injectors and it still feeling like it is missing , it has a litte vibration when its in drive and im stopped at a light other than that it drives fine. i dont know what else to do .
Old Dec 28, 2004 | 01:45 PM
bogus's Avatar
bogus
Was this vibration there before the tune up?
Are all the plugs gapped correctly? Everything tight? all connectors right? Wires correct and snug?
Old Dec 28, 2004 | 01:52 PM
babar sultan
Cruising
yes it was there before the tune up and all the plugs are right and the wires are in right and it still dose it but not as much it only has 47560 miles on it
Old Dec 28, 2004 | 02:49 PM
BLK/BLK'93's Avatar
BLK/BLK'93
The next in line would be cap/rotor or coil. Also check the elecrical connection to your opti. I have seen water damage to the pins and corrode them. Make sure there is a good connection there, and the pins are clean.
i almost forgot....a small vacuum leak will also create a low rpm miss. If you spray carborator cleaner around the vacuum hoses and places where the vacuum hoses are connected, the engine will bog down if the carb cleaner finds a leak.
Old Dec 28, 2004 | 02:55 PM
bogus's Avatar
bogus
I am wondering of a weight has been thrown from the flexplate.
Old Dec 28, 2004 | 02:56 PM
babar sultan
Cruising
where are the vacum lines at?
Old Dec 28, 2004 | 02:58 PM
babar sultan
Cruising
what would cuz the flex plate to throw the weight off
Old Dec 28, 2004 | 06:35 PM
bogus's Avatar
bogus
any rubber hose attached to the intake manifold.
bogus's Avatar
bogus
bad karma?
Old Dec 28, 2004 | 11:02 PM
Jet-Jock's Avatar
Jet-Jock
Throttle body cleaning and replace/clean IAC.
Old Dec 29, 2004 | 12:16 AM
VenkmanP's Avatar
VenkmanP
Wouldn't that cause problems all the time not just stopped at a light?
Old Dec 29, 2004 | 12:17 AM
VenkmanP's Avatar
VenkmanP
So if it's in neutral there's no problem at any RPM?
And in drive it's only noticable when idling?
How long have you had the car?
Where do you live?
Do you wash the engine?
Old Dec 29, 2004 | 05:20 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Pull the cover off the passenger side see if the 3 way vaccum black thing has a hole in it.I have gone through 2 in the last 25,000 miles.
The heat causes them to cave and start a very small vac leak.
#5 spark plug wire in the opti gets rusty and can cause a misfire.
Or its just a 94 that likes to miss on rainy day's.
Mine always has a miss at idle when it rains or when the coolent temp is below 190 deg.
I have tuner cats and tts and I still can't pin it down.
Just o-hulled the trans that was some of it.
Old Dec 29, 2004 | 05:45 PM
babar sultan
Cruising
Default 94 corvette
just bought it about 3 months ago and today just replaced the battery and cable now my sys light dosent come on anymore thanks for the tips and ill get to the bottom of it
Old Dec 29, 2004 | 10:08 PM
MikeC4's Avatar
MikeC4
Anybody reading this thread, could it be that the EGR valve(if u have it intack!) has carbon/exhaust deposits and is leaking exhaust into intake manifold at idle(which would make it choke and puke at low RPM)???? Check this by plugging EGR mount with thin piece of aluminum, from like a beer can!!!!
This problem really sounds like emmission control gremlen...
good luck with it...
Old Dec 29, 2004 | 10:30 PM
YLO Z06's Avatar
YLO Z06
2023 C5 of the Year Finalist - Modified
I think a dirty TB and IAC could be causing this. Don't forget to reset the minimum idle air after you clean the IAC. There is a Tech Tip on how to do this.
You know, the more I think about it, the more it sounds like a bad Opti. My Opti had similar symptoms when it was on its last leg. A new Opti Spark is not cheap, though. I always order mine from www.superchevyperformance.com . Ask for Chris -- he gives a discount to Forum members .
Old Dec 30, 2004 | 03:30 AM
REDC4CORVETTE
To be good at giving information is just as critical as recieveing it.
1.Year
2.Engine
3.Trans
4.Miles on vhl
5.What mods if any done to car?
Then the information can flow.
To 94 corvette viberating at ide when in drive
