Dakota Digital SGI-5 with ABS?
Old Dec 29, 2004 | 11:19 AM
LD85's Avatar
LD85
Default Dakota Digital SGI-5 with ABS?
Anyone using this with an ABS system?
Ol'RJ is using it with his ABS and he does AutoX and he has had no problems.
Has anyone had an issue with ABS and the speedo calibrator?
http://www.dakotadigital.com/Detail...I-5/product.htm
Old Dec 29, 2004 | 04:07 PM
tequilaboy's Avatar
tequilaboy
I have had no adverse effects on the ABS in my 88 with the Dakota Digital SGI-5 Interface. I am happy with the product.
Some vehicles receive vehicle speed and odometer rolling count information from the ABS module instead of a transmission mounted vss sensor. The SGI-5 would not work in these applications, but this is not a problem for our corvettes
Old Dec 29, 2004 | 05:33 PM
LD85's Avatar
LD85
Thanks, others with ABS have said there is no probelm too. Just curious, their website says no, and the email I got from them says,,
QUOTE:
Larry,
The SGI-5 is a buffer and it delays the response of the speed signal, so your ABS will not work as effective as it should, or even work at all.
_____________________________________
Best regards, Tim
Dakota Digital Tech Support
techsupport@dakotadigital.com
605-332-6513
To Dakota Digital SGI-5 with ABS?
