Master Cylinder question
Old Dec 30, 2004 | 10:15 PM
bowersock's Avatar
bowersock
St. Jude Donor '05
Default Master Cylinder question
Will a metal brake booster and 88 and up two reservior master cyclinder work on my 86L?
Thansk Roger
Old Dec 30, 2004 | 11:20 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Thansk Roger
They should!
The single vs two cylinder reservoir was just an attemt by GM to save $0.50 on the extra reservoir! Hey, 50 cents on 20,000 cars equals a lunch for the GM Top brass!
Jack
Old Dec 31, 2004 | 12:20 AM
Wayne88's Avatar
Wayne88
Originally Posted by jackdaroofer
They should!
And I thought the 2 cylinders in my '88 meant my brake system was better than an '87.
Old Dec 31, 2004 | 12:43 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
85 has two reserviors (and 3 seperate brake circuits!) I'm not sure when GM switched back and forth. two reserviors give you more room for error, and make leaks easier to diagnose.
To Master Cylinder question
