Just curious. What would happen if....
What would happen if I was at a standing start and had the RPMs up around say 3K or 4K, and (after taking up driveline slack) dropped the clutch? Would it stall? Would it churp and bog? Would it make big grins??? I ask this because I remember another member posting a video of their C4 LT4 with 4:10 gears and bolt-on mods leaving long stripes from a standing 2nd gear start. I was wondering if it would please me as such before I get the 4:10s that I eventually want to get.
Oh, and by the way....Happy New Year!
Today for example, coming out of a culdesac I revved it to 5500 and dropped the clutch.. then left foot on the brake....
It was almost boring really, roasting the tires for 10 seconds at 5500. Use the brake pedal to control your speed, but go easy on it... your rear pads won't like you.
I haven't done any 2nd gear burnouts, but those will put out some smoke fast, since the tires are spinning so fast. Make sure to drop it from redline though, to avoid burning up the clutch or stalling out in an embarassing way.
As far as taking up the slack, um, are you feathering the clutch?
That's the only way to take up slack... I'd rather wack the gears then roast the clutch. Gears can take it. Especially your straight cut ZF.Nice plates btw.
With 4.10 gears
Does this answer your question.......
Took me a while to do it the first time.......but you will really light then up......don't forget to turnoff the ASR...
