How are you guys measuring boost discharge temps?
Old Jan 1, 2005 | 01:40 PM
qwiketz's Avatar
qwiketz
Default How are you guys measuring boost discharge temps?
what temperature setup are you running to read your blower/turbo discharge temps?
The autometer trans temp one goes from 100-250f, but will the probe accurately measure air temp since it's meant for h20?
I'm picking up a guage pod and have a space to fill so I thought it would be cool to know this stuff.
Old Jan 1, 2005 | 08:37 PM
HJV11's Avatar
HJV11
I have always watched the IAT sensor using Datamaster. It seems to have worked out well so far.
Old Jan 2, 2005 | 01:59 AM
qwiketz's Avatar
qwiketz
makes sense. thanks!
Old Jan 2, 2005 | 03:21 PM
AKS Racing's Avatar
AKS Racing
Inlet air temp (IAT) is measured through the aftermarket ECMs, using their data log system (I personally use FAST). It is very disturbing to make a full 1/4 mile pass and see the temps rise from 85° to 180°+ in the dead of winter. But important info nonetheless. This is why I currently run in the very low 20° advance under full boost.
Aaron
Old Jan 3, 2005 | 03:28 AM
Mo_Bandy's Avatar
Mo_Bandy
I use the IAT reading as well...
Mo
To How are you guys measuring boost discharge temps?
