Droopy door hinge
Old Jan 1, 2005 | 11:43 PM
ALLT4's Avatar
ALLT4
Default Droopy door hinge
I did a search on this and can't believe it comes up nada. My drivers side door hinges drops about an inch when I open the door. Can I replace just the bushings like in any other chevy or do I need two new hinges.
Can anyone post some links? Parts? 96 vintage.
Old Jan 2, 2005 | 12:04 AM
Grace91's Avatar
Grace91
Old Jan 2, 2005 | 12:51 AM
mikey whipreck's Avatar
mikey whipreck
My vette doesn't have this problem, but my daily driver cavalier does... In that case the bottom hinge is almost rusted away...
in any case...
Old Jan 2, 2005 | 02:06 AM
VenkmanP's Avatar
VenkmanP
There are bushings available from the usual suppliers.
However when I've read about drooping doors they've talked about replacing hinges not bushings, so I don't know if the bushing will help.
But the bushings are $2 and the hinges $50, so I might try the bushings first.
Let us know how it turns out - a tech tip might be in order.
Old Jan 2, 2005 | 09:12 AM
brock71's Avatar
brock71
Default Door hinge sag
I have the same problem on my '88. Tried to lift the rear edge of the door last Summer. It didn't seem to even move ( yes, I did loosen the hinge bolts). I just got a hinge alignment tool for Christmas. I'll give it another try this Winter. If no luck I'll go the new hinge route.
John
Hudson, OH
Old Jan 2, 2005 | 09:21 AM
rick lambert's Avatar
rick lambert
There probably isn't a tech tip, however someone on the forum did a post not toooooooooo long ago about getting some bushings at Home Depot (I think) and using a bolt.
To Droopy door hinge
