Small Diameter Distributor Swap, part #'s
Chris-I am changing from the Miniram to the Superram and want more clearance, that "Pizza Box" is big. I dont have enough cam to make the Mini perform as well as it could and I think tuning will be easier with a SR too.
:He has a machine he can run them on and test them for bad bearing and other items. It can spin them pretty fast ~10k rpm if he so chooses. Anyways. He swears by the larger diameter caps for racing as opposed to smaller aftermarket ones.
He said you put an MSD box on or an aftermarket coil, its very common and fequent with the small caps you will get spark scatter (wrong post getting the charge for you guys unfamiliar with the term). That is #1 destroyer of engines - pre-ingition.
He said it doesn't even have to be at a very high RPM for it to happed either, although the faster they spin, the more likelyhood you can create it.
If you look on the big guys cars like force and them they have distributers the size of garbage cans. You see the smaller the cap, the closer the posts are to one another. The larger the great the posts are spread from one another.
I was going to buy an aftermarket cap for mine till he shared that tid bit of information with me.
But does anyone know @ how much smaller this cap is, just aprox?
Art
Maybe someone can post some pics of the Distributor clearance for me.
He says to stay with the stock corvette HEI or go to a MSD 8366 because the MSD 8366 is a much beter built unit.
More good info, so I will ship around for an MSD or stay with the factory distributor.
Thanks SKI for the heads up.
You can use the large cap no with no problems in conjuction with the SR.
LD85 - good to see that someone else verified this with the smaller caps.
It might be worth having someone rebuild your stock unit for piece of mind.
It appears that it is a good mod, but you gotta spend $225 on an MSD cause a factory unit wont get it done right.
So I will just spin the distributor a tooth to get it where I want it and for the best clearnce.
I hope all is well for you West Coasters out there!
