Antenna won't go down
Old Jan 2, 2005 | 09:40 AM
rstmeredZ's Avatar
rstmeredZ
Default Antenna won't go down
The power antenna on my 92 coupe just stopped going down. What do I look for or check first?
Old Jan 2, 2005 | 10:36 AM
newbecorvetteguy's Avatar
newbecorvetteguy
I would first check the fuses. Then I'd check the relay located under the plastic trim back by the rear hatch latch...at least that's where it was on my '87. One wire should have 12v to it all the time to power it down, another wire should just have 12v to it with the radio and ignition on.
Old Jan 2, 2005 | 11:04 AM
ittlfly's Avatar
ittlfly
Do you hear the antenna motor run when you turn on the radio? If yes, then you probably have a broken ribbon. If not, check the courtsey light fuse in the fuse panel.
Old Jan 2, 2005 | 02:56 PM
Strick's Avatar
Strick
If the motor runs but the antenna doesn't move, you'll probably want to see this:
http://forums.corvetteforum.com/showthread.php?t=975529
Old Jan 2, 2005 | 03:01 PM
MrRenoman's Avatar
MrRenoman
Try pushing down or pulling up on the antenna mast gently. If it's sliding up and down, the mast plastic cord is broke. You may hear the motor running too. If all is firm, it could be the relay, wiring, or circuit and/or fuse..
Art
To Antenna won't go down
