I have an '87 that will not start all the time. I think its the problem with the key not being read. So until I can find the time to replace the sensor on the ignition switch I'm going to bypass the VATS. I checked the key with an ohm meeter I it registers 680 ohms or GM VATS code 03. I found some instructions that say that all I need to do is connect a 1/4 watt resistor into the harness after I disconect the sensor. I have 1/2 watt resistors in my spare parts bin. Will these work or will I fry the VATS module with the wrong resistor size of 1/2 watt?
You got good advice from corvette90! Arrange to have your ignition tumbler replaced, it has new contacts for the pellet. 99% of thefts are done by bashing the column and jumping the ignition, don't permanently bypass your VATS!
