LT1 valve cover bolt question
Old Jan 2, 2005 | 10:23 PM
POLOVETTE 94's Avatar
POLOVETTE 94
Co-winner 2020 C4 of the Year - Modified
Default LT1 valve cover bolt question
I never realized this, but the valve cover bolts are actually 2 pieces? The torx bolt screws into a stud, which screws into the head. Now, for my coil packs in the Delteq system, I need to leave three studs in, and use the bolts from the kit to bolt the plate holding the coils to the valve cover, and of course, the bolt won't come out of the stud. Where can I get new studs, or while I'm at it, how about those chrome torx bolts? Thanks for any help.
Old Jan 2, 2005 | 10:50 PM
Bruce's Avatar
Bruce
hey
I just did the delteq install but not complete yet. But at least I mounted my coil on the valve cover. Here how I did mine. Use a T50 torx to loosing the valve cover bolt. The bolt are in two piece. If the whole bolt are coming out then you will need to clamp it on a vise with rag and than try to loosing the cap.
Bruce
Old Jan 3, 2005 | 12:29 AM
bogus's Avatar
bogus
I used some really long bolts when I did the LTCC... they are 1/4-20. Available for next to nothing at your friendly hardware store.
I cut the heads off and used them as studs.
To LT1 valve cover bolt question
