LT-4 conversion kit for LT-1
Old Jan 3, 2005 | 12:22 PM
tm1995c4-LT1's Avatar
tm1995c4-LT1
Default LT-4 conversion kit for LT-1
I seen a conversion kit for an LT-1 mentioned on this forum a few times. Can someone give me some info on this please. Parts, price, where to get it and all that good stuff! Thanks!
Old Jan 3, 2005 | 12:26 PM
BDVETTE96's Avatar
BDVETTE96
its around 2,200 dollars, it will give you a 30 hp increase but it is a lot of money to spend for 30 hp.
Old Jan 3, 2005 | 12:50 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
I've seen them atsummit , jegs , and scoggin dickey
The difference between the LT1 and LT4 was the heads. The LT4 has an improved design that provides better flow through raised runners, thus the difference in intake since the runners will not match to that of the LT1. From what I've seen, porting the stock heads or getting some aftermarket heads (AFR, Edelbrock, ect...) is a more cost effective way of producing power. It may be something to look into.
Old Jan 3, 2005 | 01:54 PM
redbullapril23's Avatar
redbullapril23
the best bang for you buck would be getting your stock heads ported and polished and the intake ported to match from www.precisionporting.com these heads will use your stock ones and out flow the stock lt4 heads
you can get it for about $1200
then buying a Lt4 hot cam kit -less than $500
and with that you get the lt4 hot cam, lt4 springs, 1.6 rrs etc
you are now at 1700 and for less than $500 you can get a tune!
that way youll make sure you get all the hp!
youll be about 45-70 hp better than b4!
and its the same price!
just my 2 cents
Old Jan 3, 2005 | 02:10 PM
tm1995c4-LT1
Great stuff to know. Thanks everyone!
Old Jan 3, 2005 | 04:41 PM
VenkmanP's Avatar
VenkmanP
It's widely advertised as 125 HP. Now whether it gets 125HP in the real world is questionable (the test was with LTs and open exhaust), but it's a lot more than 30.
Also you can get the parts for quite a bit less than $2200 if you shop around.
Plus everybody always fails to realize that if you go the LT4 route you get to sell your LT1 heads and cam to recoup a little of the cost.
Old Jan 3, 2005 | 05:37 PM
redbullapril23
yea I hate when companies advertise hp as crank hp or flywheel
its like 30 at the wheels! is what we are saying!
Old Jan 3, 2005 | 05:43 PM
Zix's Avatar
Zix
An LT4 conversion kit gives you more than 30 at the wheels. It would likely (on average) bump a stock LT1 from the 260-270RWHP range to the 320-330RWHP range. All these kits (that I have seen) come with the LT4 Hot Cam kit, not the stock LT4 cam so there's a nice bump with the combination of the better flowing heads.
Old Jan 3, 2005 | 05:52 PM
redbullapril23
but for the same price you can get the lt1 stg3 ported heads for even more hp!
Old Jan 3, 2005 | 05:54 PM
95PoloVert's Avatar
95PoloVert
Active Streak: 90 Days
Default One F/S for $1800 over in the Parts Forum
Great deal, if you're going this route!
Old Jan 3, 2005 | 06:09 PM
redbullapril23
i already got dibs on head and intake
Old Jan 3, 2005 | 07:06 PM
VenkmanP's Avatar
VenkmanP
Gotta hate those 75% drivetrain losses...
Old Jan 3, 2005 | 07:12 PM
VenkmanP's Avatar
VenkmanP
You think it's a bad idea, so you're getting one?
Old Jan 3, 2005 | 07:42 PM
redbullapril23
well I'm gonna get them stg 3 ported from precision porting
and get the intake to match
I am saying for the $ you can get batter flowing heads! and thus more hp
but if you have lt4 heads then get them coated the stg 3 lt4 will out flow stg 3 lt1 but its like alot more expensive! and at that you might as well get AFR heads if you start from scratch!
your friend
Sean
Old Jan 3, 2005 | 07:47 PM
VenkmanP's Avatar
VenkmanP
your friend
Sean
So you're saying it's better to get the AFR heads, so you're buying the LT4 heads?
Old Jan 3, 2005 | 07:54 PM
VenkmanP's Avatar
VenkmanP
well I'm gonna get them stg 3 ported from precision porting and get the intake to match
From what I've seen of flow #s, if you're going to get a substantial port job, then you are better off getting the LT1s ported than getting LT4s. As the amount of porting increases, the difference in flow #s between the two shrinks.
Also, with a stage 3 port you are presumably getting bigger valves, so you're discarding the special LT4 valves.
And in that case you would be better off getting bare LT4 heads instead of the ones in the kit, since you're not using the valvetrain components anyway.
Old Jan 3, 2005 | 08:13 PM
Zix's Avatar
Zix
Only the exhaust valves on the LT4 are special, as they are sodium filled. A heavy ported LT4 head will still outflow a similarly ported LT1 head. I have a set of stage 4 LT4 heads that flow a little over 315CFM...I haven't seen that out of LT1 heads before.
To LT-4 conversion kit for LT-1
Old Jan 3, 2005 | 08:17 PM
redbullapril23
now the smaller flowing afr heads arent worth it in my mind but the 210cc is! it jsut depends if you wanna go all out or get the best bang for your buck
i want the bang for buck. I am not saying i am gonna buy the lt4 heads i just wanna see how much he wants and if the price is right I will buy!
well these are just my opinions you dont have to agree with them or listen to them.
Old Jan 3, 2005 | 08:27 PM
RadPolo96's Avatar
RadPolo96
Im with redbullapril23 on this. I just got some stage 2 heads from precision porting for 1200 and a custom cam as well as stage 3 LT4 intake. All for the same price as this conversion kit and I expect to make alot more HP than they claim for the same price. I will post after it is all installed with results. I would talk with Bob at precision porting. He can set you up with some awesome heads for cheap and is very knowledgeable on the subject. He is also doing a Group purchase price right now for stage 2 for $1k. http://www.precisionporting.com/vettegp.html
Old Jan 3, 2005 | 08:43 PM
VenkmanP's Avatar
VenkmanP
I'm just trying to figure out what your opinion is. Earlier you said the LT4 are a bad bang for the buck, now you say you are interested in them because they are a good bang for the buck.
