sway bar weight?
Old Jan 3, 2005 | 09:42 PM
1996man's Avatar
1996man
Default sway bar weight?
how much do these things weigh? i know a lot of serious guys take them off to drag race but just curious how much stock ones weigh. i know heavy duty aftermarket performance ones weigh more
Old Jan 3, 2005 | 09:47 PM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
Man, you are really getting your post count up by asking every single weight question in a different post.
Old Jan 3, 2005 | 10:47 PM
MYCoupe's Avatar
MYCoupe
Well they don't take them off for the weight savings, although it is a benefit. You get better weight transfer without a front sway bar, that's the reason they take it off.
I have a stock Z07 (30mm) front sway bar in my garage right now waiting to be installed. Just by picking it up I can tell you that it probably weighs around 25 lbs.
Old Jan 3, 2005 | 10:51 PM
1996man's Avatar
1996man
LT-4 CE i find i get better answers this way!
thanks for the info! i had no idea they weighed that much! how does not having it on there help weight transfer?
Old Jan 4, 2005 | 07:49 AM
bowersock's Avatar
bowersock
St. Jude Donor '05
Default sway bar weight-
I just replaced both sway bars with much larger VBP pieces and I can tell you they weight ALOT- especially the front
Roger
Old Jan 4, 2005 | 11:03 AM
c4cruiser's Avatar
c4cruiser
The front bat on my 87 Z52 car is solid and I think it weighs about 30-35lbs. The rear bar is tubular and weighs about 10 libs. Base suspension Vettes had tubular front bars so the weight of those versions would be about 15-20lbs.
The front bar is not that easy to remove completely from the car. Unbolting the bar from the lower control arms help for drag racing as the front control arms are not held back by the friction of the swaybar bushings on the bar thus allowing for somewhat quicker weight transfer.
Having the bar disconncted for street driving will seriously degrade handling.
Old Jan 4, 2005 | 11:12 AM
LT-4 CE's Avatar
LT-4 CE
Just giving you a hard time.
Old Jan 4, 2005 | 11:32 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
It's been a while, but my bar didn't weigh 30 lbs, maybe 10.
Old Jan 4, 2005 | 12:23 PM
jp2002ls1's Avatar
jp2002ls1
My 1985 Z51 has the 30mm SOLID bar and it weighs 32 pounds, the rear one is also solid and heavy but I can't remember how much it weighed.
Old Jan 4, 2005 | 09:58 PM
NitrousSam's Avatar
NitrousSam
Anyone remove one from an 84 yet? I am wondering if miine is solid or tubular?
Old Jan 5, 2005 | 09:19 AM
dynalead's Avatar
dynalead
'84 only had solid bars:
FE1 24S, 20S
Z51 25S, 23S
Old Jan 5, 2005 | 10:57 AM
JCD's Avatar
JCD
Total weight reduction is only half the answer. In a 2wd vehicle your maximum acceleration is limited to the % of weight over the driving tires.
Removing weight from the front of a vet is more benifitial than removing weight from the back.
This is a big part of the reason why the porsche 911 can run the 1/4 in the same time as a vet with much more horsepower, because the engine is in the back, giving it a much better weight ratio for the back wheels (and less inertial weight to transfer from the front to the back).
Old Jan 5, 2005 | 07:49 PM
tkrussell's Avatar
tkrussell
Weights on my 95 bars (all GM)
Front 26mm Tubular (stock) 5.5#
30mm Solid Z51 15#
Rear 24mm Solid (stock) 13.5#
26mm Solid Z51 14.5#
Note how much weight is saved with a tubular bar !!
Wish there was a 300mm Tubular for the C4.
To sway bar weight?
