The car starts and idles ok when it's cold but if I stop and restart after running for a while it doesn't maintain idle speed. The car will drop the revs to 400RPM and stall. I've run an injector cleaner thru a tank of gas and that seemed to make a small difference but it seems to be a problem still and I'm wondering if anybody has seenthis before???
Assuming (hate that word) your 88 or 89 doesn't just need a good tune up-I'd check my vacumn lines first-then I'd suspect IAC, go to this website www.dvcorvettes.com/clean_air_passage.htm
After checking IAC, if you still have your original injectors I would check to see if they are leaking or clogged. What year is your car and how many miles?
From: If you don't weigh in you don't wrestle Road America
I would try cleaning out your throttle body, just get some rags and a bottle of carb cleaner and go nuts. This will help with the IAC as well. if that doesn't work then I would look at the injectors. If you have a fuel pressure gauge just start the car and watch the gauge over 20 minutes if the fuel is leaking down the pressure will drop, it should stay solid though.
OzzyVette, I have the same symptoms on my '95. The engine idles fine for about 30 minutes or so of driving, then my idle get's rough and drops to about 400rpm. At this point, my "service engine" dumbo light usually comes on. Car has 66K miles. Anyway, I removed the TB and thouroughly cleaned it. I cleaned the carbon crap off of my IAC. I replaced intake gaskets, front and rear intake RTV using "The Right Stuff", and new plugs. I also ran added bottle of Redline to the gas tank. After all of this, I still have the same Idle problem...
I might bit the bullet and spend $65 for new IAC, and hope that solves it. When the Idle drops to ~400RPM, it sux 'cuz it feels like the engine will quit at any moment. I turn of AC to reduce load on engine, and put car in neutral at lights.
When the car cools down, everything goes back to normal.....up until I drive for 30 minutes or so.....
I know this is going to sound dumb but what is an IAC???
Yes as far as I know they are original. I have run a couple of tanks thru with injector cleaner as well as cleaning the throttle body with carb cleaner and it seems to have made a small difference but the car still lacks power on what it used to be and "feels" like it should be going harder than it does.
IAC= Idle Air Control, the web site I posted is well worth going to and reading, especially if you're having Idle problems.Remember, our cars are 16-17 yrs. old, with alot of carbon build up, simply running carb cleaner thru it might help a little-but it probably needs a thourough cleaning
Here's a little more detail on IAC:
The IAC(idle air control) valve is an ECM voltage controlled stepper motor which should be open during idle. This should allow a small but sufficient amount of air into the intake through a TB cutout passage. The engine needs this air during idle time 'cuz the throttle plates should be closed at this time(unless someone has turned up the idle screw which is a no-no). Your IAC should be located at he base of your TB, with a 4 pin connector going to it. You may not be able to see it unless you remove the air intake duct which is attached to the front of the TB.
hey ozzyvette,
I've been having the exact same symptoms with my '90. I talked to a friend today who has one and he suggested checking the EGR (exhaust gas recirculation) valve, which is located under the intake plenum. I checked my hoses and stuff and they appear to be ok. I'm thinking about ordering a new EGR and hoping for the best. I've tried all the TB and injector cleaning too but it dosen't seem to help. I also tried disconnecting the IAC valve and the idle shot way up to 2000 RPMs. Then I plugged it back in and it settled down, so I'm assuming the IAC is still functioning. Anyway, hope this helps. Good luck.
hey ozzyvette,
6speedshifty, interesting test procedure for IAC. This means that with no reference voltage, the IAC default position is open, ie the plunger retracts into the IAC when you disconnect...
