Cut lid/Filter
Old Jan 4, 2005 | 02:12 PM
Darth Vader's Avatar
Darth Vader
Default Cut lid/Filter
Will just a cut lid and a stock airfilter do anything in terms of performance??? For a 96 LT1?
Old Jan 4, 2005 | 02:20 PM
sniperdiver37's Avatar
sniperdiver37
Being new to the " Corvette" world myself I have done alot of reading here. Cutting the lid on the air box is free HP. Stock filter is not. Air in/ air out is Good. I did mine on my 88 but have a K&N filter. It worked for me. But they also don't make aftermarket air boxes for my car YET..
If you read through some of the postings you will find tons of info and it's all free and you will find some free HP also... Good luck
Old Jan 4, 2005 | 02:34 PM
Perfusion's Avatar
Perfusion
I've not heard of anyone doing a cut lid + stock filter before, so I don't know... I have an open lid and a K&N, myself. I found the filter on eBay for $20, so I couldn't pass it up. It's pretty much accepted that a *NEW* paper filter will flow as well as a clean K&N, but a dirty paper filter won't flow nearly as well as a dirty K&N (which flows as well as a clean one...). For $20, it's the last air filter I'll ever have to buy for the 'Vette. That, alone, is good enough for me. If I get 3-5hp out of it, that's a bonus...
Old Jan 4, 2005 | 02:49 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
The cut lid won't do anything for performance, nor will adding a K&N to the cut lid.
I have hundreds of runs to back me up on this. An open lid just means you get your filter dirtier a lot quicker.
Supposedly on the L98 cars it's makes some differences, but on the LT1 it makes no difference at all.
Old Jan 4, 2005 | 03:33 PM
vader86's Avatar
vader86
On the LT1, probably not. Your intake tract is well-designed and not restricted.
On the L98, yes.
Old Jan 4, 2005 | 03:52 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
It is debatable whether it is beneficial or not... I only challenge with this statement. If you stick a straw in your mouth and try to inhale only through a small straw... it will be difficult. If you increase the diameter of the straw to twice the size and repeat, you will get more air the second time around. For what it's worth, it is a free mod so I did it even if it doesn't help... it doesn't hurt so why not...
Old Jan 4, 2005 | 04:08 PM
redbullapril23's Avatar
redbullapril23
i agree with the statement that
with keeping the stock filter not much happens
but k an n yes!
i think vader is correct too
it dont help much on a stock lt1 but if you are running say like a 383 or a modified lt1 then u need more air with the combo of lts and free flow mufflers then itll make a difference
your friend
Sean
Old Jan 4, 2005 | 04:32 PM
Mr Mojo's Avatar
Mr Mojo
Take a good look at the LT1 setup. There is a rubber strip that seals off at the top. I had measured to openings on both type of LT1 air cleaner lids(there are two different ones), they are roughly the same despite the difference in the openings.
Bottom line is, on a stock LT1 it makes no difference if you have a cut lid or not and the K&N makes no difference. The advantage to the K&N is the million mile warranty. The paper ones you have to replace every so often.
Trust me on this, on a stock LT1 there is no difference.
Did I mention there is no difference?
BTW, there is no difference.
You know what else? There is no difference.
I can't see the difference which leads me to believe there is no difference.
Can I stress enough that there is no difference?
Old Jan 4, 2005 | 04:37 PM
Lichen's Avatar
Lichen
So let me make sure I understand you correctly. On an LT1, there is no difference?
Old Jan 4, 2005 | 04:38 PM
Nathan Plemons's Avatar
Nathan Plemons
http://forums.corvetteforum.com/showthread.php?t=564602
Old Jan 4, 2005 | 07:18 PM
SSLT1KID's Avatar
SSLT1KID
here is a question, will an L98 filter fit an LT1?
Old Jan 5, 2005 | 12:48 AM
kwik_ta's Avatar
kwik_ta
I won't even comment.
Old Jan 5, 2005 | 08:02 AM
runner140*'s Avatar
runner140*
Default About a year and a half ago...
I added a cut lid and a K & N on my 1996 and found no difference. Thats just my reflections. I guess each vette might be a little different.
Old Jan 5, 2005 | 08:40 AM
HeeHaw89's Avatar
HeeHaw89
Hmm, imagine that...no difference!
BTW, I have a cut lid and a stock filter.
Old Jan 5, 2005 | 09:16 AM
proemtpff's Avatar
proemtpff
Maybe there is no difference with the LT1 but with my L98 there was marked improvement.
Old Jan 5, 2005 | 09:46 AM
cv67's Avatar
cv67
St. Jude Donor '05
I think he meant there's no difference!
Folks we have another debatable thread!
Old Jan 5, 2005 | 11:43 AM
proemtpff's Avatar
proemtpff
Come on now.......is there a difference with the LT1?
To Cut lid/Filter
Old Jan 5, 2005 | 12:08 PM
Tigerhawk's Avatar
Tigerhawk
Oh come on, K&N promises 10 hp.
Old Jan 5, 2005 | 12:14 PM
Nathan Plemons
In my mind the debate ended when I did the dyno test. It shows a solid horsepower gain on my heads / cam car, shows virtually nothing on a stock car. End of story, for the LT1 anyway.
Old Jan 5, 2005 | 02:35 PM
proemtpff's Avatar
proemtpff
So, what your trying to say there is NO DIFFERENCE?
