Understanding Opti Codes-HELP
Old Jan 4, 2005 | 05:12 PM
CharlieLT4's Avatar
CharlieLT4
Default Understanding Opti Codes-HELP
Help me understand the opti codes...what is A/B?
What codes will an opti cause?
My Corvette only has 24,000 miles and this will be the third cap and rotor and the second opti.
Thoughts on using a GM opti and the MSD cap and rotor or use the complete Dynotech Engineering unit?
I only want to replace this once!
Old Jan 4, 2005 | 05:21 PM
GlockLT4's Avatar
GlockLT4
Thanks for starting a new one . You'll get more responses with a good title anyway.
The normal codes that you get for the opti are the hi-res and low-res signal ones. I believe they are 33 & 34 ? I'd have to look to double check.
How are you checking for codes?
Old Jan 4, 2005 | 05:39 PM
CharlieLT4's Avatar
CharlieLT4
Paper clip and drivers information center...
Old Jan 4, 2005 | 05:40 PM
GlockLT4's Avatar
GlockLT4
What codes are blinking?
Old Jan 4, 2005 | 05:48 PM
FD2BLK's Avatar
FD2BLK
16 is the most common if it throws acode, it probably wont. 16 is the low res signal.
Old Jan 4, 2005 | 06:20 PM
96GS#007's Avatar
96GS#007
Since you have "LT4" in your screen name, I assume you in fact do have a 1996 LT4.
With my above assumption, A/B means nothing in your case unless you or someone else has converted the car to an earlier OBD I PCM. If the PCM is unchanged, on '96s, you can't jumper pins A & B of the Assembly Line Diagnostic Link (ALDL) to get Powertrain Control Module (PCM) codes. FWIW, the ALDL pins are numbered vs lettered on '94 and later cars.
To pull PCM codes on a '96 you have to have a scan tool or laptop based scan software. AutoZone will pull the codes for free.
All '96 PCM codes (including codes for the Opti) are Pxxxx, where xxxx = a numerical code such as P0300 which is a Misfire code).
If your Service Engine Soon light isn't on, no codes are present.
The codes you can pull on a '96 (and earlier models) are CCM, ride control, and some ABS and ASR codes.
If you want to avoid cap and rotor issues in the future, then something like the DelTeq or LTCC systems are the way to go versus the DynoTech opti.
To Understanding Opti Codes-HELP
